Results 1 to 11 of 11
Thread: 2 year paver problems
    Jun 2014
    sandwich, il
    4
    I have done a lot of reading here. Thanks for all the information provided here. Now I have a question. This is the second year that I have set up my intex 32*16 ultra frame pool. I used the same pavers as last year, which are 8 inches wide*16 long *1 1/2 high. Last year I had 1 or two blocks sink on the front end and tip so that the end of the support was at the front of the block, but I let it go and had no problems.
    14000 gallons
    Above ground pool - Intex 16ft x 32ft x 52 inches
    saltwater system pump model CS20110
    Brand new pool
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: 2 year paver problems
    All I can think of is to get bigger blocks and make sure the poles are put on in such a way that IF the block tried to tip/move with the pole there is still plenty of block for it to stay on.
    Wet ground has a lot of give. I bet the dirt is giving under the weight of the pool.
    Good luck!
    Kim
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Maybe put a base of some type of rock under the pavers?
    currentking's Avatar
    Jun 2015
    Palm Bay Florida
    91
    i would agree with PAGirl. Or you could stack 3 pavers like a pyramid which would give more ground taking the weight.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Eddd's Avatar
    May 2015
    Frisco, TX
    53
    put 3+ inches of gravel underneath the pavers. Of course if the ground gets REALLY wet (souply) your only option is to double or triple your stone length, but then you run into strength issues (stone could break). If it were me, I'd put a bed of gravel (3") then sand (1") then stone. Kinds like how you would lay a normal paver deck.
    Good luck!
    About to build an in-ground free-from gunite pool in the back yard (no spa). Currently estimated at 19,000 gallons. Likely going with a SWG.
    Jul 2012
    Tallahassee, FL
    30,444
    Quote Originally Posted by Eddd View Post
    Good luck!
    I like this idea the best! We have a winner!
    Kim
    Jun 2014
    sandwich, il
    4
    Thanks for all the replies. Is the pool ok to swim in if I leave it be? All the other sides are fine and the water is level within an inch or two. I really don't want to drain it and refill after thinking about it.
    14000 gallons
    Brand new pool
    Jul 2012
    Tallahassee, FL
    30,444
    Do you have any kind of help that can/will help you use something to get the let up and paver back under it?
    Kim
    Jun 2014
    sandwich, il
    4
    Yes, I have someone to help me but I am not sure how to go about it.
    14000 gallons
    Brand new pool
    Jul 2012
    Tallahassee, FL
    30,444
    I have been thinking about it more. I am worried that any attempt to lever up the pole going down will cause it to bend more
    Maybe just try to shore it up so it does not sink any more and find a way to support that area. 2x4s with a groove notched in the top to fit the top rail in with pavers under them? One on each side of the low pole?
    Above all else be careful that it does not sink more.
    Kim
