Thread: New install
    Jun 2015
    Tupelo Ms
    18
    New install
    So in preparing everything to make sure I have everything. I have a question do you spray a ground sterilizer on ground after removing turf and leveling. I will be using the 3/4" extruded polystyrene foam panels instead of sand my yard is mainly sand. If you do spray a sterilizer what kind do you use. Thanks in advance
    Casey's Avatar
    SW PA
    10,461
    Re: New install
    You don't have to unless you have an invasive grass or weeds growing.
    PaulfromCT's Avatar
    Sep 2013
    Connecticut
    27
    Re: New install
    I did sprinkle Diatomaceous Earth Ant/Crawling Insect Killer under my extruded polystyrene---just an extra safeguard and it was cheap. Read somewhere on this forum that it was suggested. Troublefreepool.com was an incredible source of information and could not have done my project without the help of the people on this forum.
    24' X 54" round AGP with Uni-Bead Portofino Liner - 25 Gauge, partially in-ground. Hayward Perflex EC-40 D.E. Filter System 1-HP Power-Flo Pump. Installed Spring 2014.
    Jun 2015
    North East, MD
    1
    Re: New install
    Diatomaceous earth sounds like an excellent suggestion. I currently use it on my chicken coop under the bedding and I believe that unwarranted use of herbicides is a very very big problem.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: New install
    Nut grass is the biggest problem from what I have read. If you have it in your yard, I would spray, and spray with something that is persistent for a least a couple months. This of course is just my take on the situation. (having a large amount of nut grass myself)
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
