Thread: Easy way to put pool cover on by myself?
    Jun 2015
    Papillion, NE
    9
    I recently bought a pool cover for my pool (24' diameter). Is there an easy way to put the cover on by myself? I have tried in the past and what typically happens is that it sinks into the pool. I have seen the hoists that some people have built but that's not entirely practical in my situation. Any recommendations would be greatly appreciated!
    Pool cover - 24' Round Metal Frame Pool Cover - Intex
    12.5K gal, AG, 2500 GPH Krystal Clear™Model 633TFilter Pump, Intex Type B cartridge filter, installed 5/30/2015, TF-50 test kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,627
    Re: Easy way to put pool cover on by myself?
    Thinking out loud here:
    -idea to use as a roll up pole------PVC pipe? the thicker the better so it does not bend/give in the middle. Long enough to go across the pool with some left over so it does not fall into the pool.
    Find a way to attach the cover to the middle of the pole on one side. Roll the pipe slowly making sure to keep it even. Find a way to secure it at the other end so it will not fall off.
    I have NO idea if this will work. It is just want popped into my head when I read your post. LOL
    Kim
