Thread: Cant get suction then when I do it fails
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    I have a ) - Mystery to me ) pump / suction problem.
    I can not get a suction to stay on a water fall only line.
    This is a single suction line from one skimmer about 50 feet to a a 3/4 hp Dura Glass pump that returns to a waterfall and slide.
    When I opened the pool all worked fine. Then it stopped.
    The pump has been rebuilt and quickly pushes water out of the basket. I have tried pushing water, air and even a flexible plastic snake 15 feet up the line.
    It appears that I have a block, but I have a weird issue. If I put a hose and pulse bulb in the skimmer I can flow water into the pump but as soon as I begin to get prime -- if I take the hose out -- I get a massive amount of water dumping into the skimmer (like pouring water into a hole) then it stops priming.
    I have not tested for an underground suction leak, but I am not loosing any water.
    I will try to post a video later.... but i am stumped....
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Cant get suction then when I do it fails
    Surging like you describe is most usually a stuck weir flapper or low water. The pump catches prime, it sucks the skimmer dry, loses prime, skimmer refills. Repeat.
