Results 1 to 14 of 14
Thread: Water line tile...is it required?
    Jun 2013
    Fort Worth, TX
    68
    My pb has done pools where they take the pebble straight to the coping and don't install tile at the water line. What's everyone's thoughts on this?
    Fort Worth, TX
    Inground gunite 32'x20' freeform salt pool Coping: Flagstone Finish: Undecided Decking: undecided Equipment: All Hayward. 3hp VS pump, largest cartrifge filter, 400k heater Cleaner: undecided robot for sure.
    Start Date: Whenever it stops raining!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Water line tile...is it required?
    We can't answer you as well because you don't have your location listed on your profile. If you could add that, I'll be able to answer you better. Some places it would be a no for sure. Some locations it might be borderline acceptable. Generally it's not a good idea.
    Essential Links:
    Jun 2013
    Fort Worth, TX
    68
    I'm in fort worth,TX. And will update my signature once I get to a computer
    Fort Worth, TX
    JoyfulNoise's Avatar
    May 2015
    13,231
    Well, it all depends on how good you are at keeping the water from scaling calcium. Calcium scale on tile is, relatively speaking, way easier to clean than calcium scale on PebbleTek. The only way to treat heavy scale on PebbleTek is with glass bead blasting and, even then, it never comes back to original. As well, because the water chemistry is slightly different at the surface near the pebble/surface interface, mild color changes to the underlying pebble creme (plaster) is inevitable. You will eventually get a water line there.
    So tile is used to mitigate a lot of the ugliness that can occur with partially submerged PebbleTek. Personally, I would demand a tile line or I would hire an independent contractor to do the tile job BUT it has to be done BEFORE the coping is poured or installed.
    Matt
    Jun 2013
    Fort Worth, TX
    68
    That makes sense. My brother is my pb and is doing the build at cost so I might as well put some tile up. He recommended it anyways, I'm just looking for ways to cut down on costs
    Fort Worth, TX
    May 2015
    13,231
    What's your pool's perimeter length in ft? Stone or poured coping?
    Matt
    Jun 2013
    Fort Worth, TX
    68
    110' plus 8' round spa. Haven't decided on coping yet but will likely just go with flagstone. Definetley not poured.
    Fort Worth, TX
    May 2015
    13,231
    Quote Originally Posted by jparadise81 View Post
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    So your perimeter is looking to be about 60 sq ft of tile. How much of the spa do you plan to tile?
    My point is, tile is/can be cheap as long as you keep to the simple tiles (no fancy patterns, etc). And don't do glass, it's a nightmare. Many times the stone masons doing the coping work will be doing the tile line too and since you're doing flagstone, the tile cost is in the noise.
    The flagstone, I hope you're doing 3" thick? The 1-1/2" stuff is cheesy looking in my opinion.
    Matt
    Jun 2013
    Fort Worth, TX
    68
    I haven't picked the flagstone but will definetley go thicker if I have the option. Thanks for the replies. I should probably stop being lazy and just start a build thread lol
    Fort Worth, TX
    Jan 2015
    Tuttle/Oklahoma
    147
    JoyfulNoise why is Glass tile a nightmare?
    My Pool Build Thread: 21 x 40 Freeform Gunite Pool, 12" Tanning Ledge, 3.5 shallow graduating to 4.5, 8.5 deep end, 4' Waterfall which doubles as a diving ledge with 6' x 4' Grotto underneath, 670 sq. ft., 106 Linear ft., Rock Salted Concrete Deck, Pentair 520 Filter, Intelli flow 3 HP VS pump, (4) Color LED lights, Intelli-Chlor SWG, Hot Springs Vanguard Hot Tub with ACE and BT Sound System, ODK, TF100
    Mar 2015
    Montgomery Texas
    112
    Yes why is glass a nightmare? My mason guys installed it and was cake.
    May 2015
    13,231
    To all glass people - I'm not trying to pick a fight. Here are my reasons that are purely subjective and personal -
    1. Glass color can depends on the backing glue color if the glass tile is not backed with a white coating. If not done right, it looks bad. Also, having laid more tile in my life than I ever wanted to, 1" glass tile on vertical surfaces is a nightmare to lay. Mixed rectangular and squares is even more of a nightmare.
    2. Calcium scale on glass looks ugly
    3. Incredibly hard to clean glass tile with calcium scale as it is easily scratched.
    Now, with that said, if you've done glass tile in your pool and you're happy with it, great for you. I'm glad. I don't like the look of glass tile at all and I would never use it or recommend it. That's my personal preference and opinion which is just as valid as yours. Feel free to voice your own opinions about glass if you like it.
    Sorry if I sound prickly, but I know how social media works and, especially, internet forums - folks read something and, because they don't know the person posting and they don't like seeing subjective opinions contrary to their own, they ramp up their outrageously outrageous outrage machine to DEFCON 5 as if a slew of bad things were just said about their mother. Then, in less than a post, it goes from being a discussion of ideas to series of ad-hominem attacks.
    By all means voice your opinions loud & proud but please keep your emotionalism to yourself.
    Matt
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Check out my build thread in my signature. I don't have any waterline tile. My decking rolls into my coping which is my waterline material. It's all concrete.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I think no waterline tile and plaster in place of it would be a very poor choice in Texas, but there is nothing wrong with glass tile. It is no more a nightmare than anything else! CH scaling looks bad on anything. I've managed my pool for a year being over 700 CH without a trace of waterline scale. If you like glass tile then by all means get it. Especially at cost. No Brainer.
    Essential Links:
