Results 1 to 13 of 13
Thread: Green pool
    Jun 2015
    Southdeerfield, Ma
    3
    Green pool
    Hi,
    I'm new to this website so I apologize if I'm posting in the wrong place. At the house my boyfriend and I currently live in the pool hasn't been used for 5 years. We have quadruple shocked it twice in the last two days and it now looks like this. I have no idea what I'm doing with a pool so any advice would be helpful.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,189
    Re: Green pool
    Welcome to TFP!!
    My first suggestion is to stop going to the pool store for shock. Their only response it to sell you something.
    I will tell you, it didn't turn green overnight and it will take time to clear. But, we can teach you how to get it sparkling and keep it that was for a lot less money than the pool store.
    Not much credence is given to pool store testing around here. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their testing. But, what can you do?? We base our pool care system on accurate testing and only adding what the pool needs, when it needs it. To do that you need your own accurate test kit. Order a TF100 and at least include the XL option. That will give you what you need while you are clearing the pool, and probably enough reagents for a couple of years normal use.
    While you wait for it to get delivered, you have a homework assignment. Start with Turning Your Green Swamp Back into a Sparkling Oasis
    Support the site
    Jun 2015
    Jackson, NJ
    123
    Re: Green pool
    How do you discern the color changes on a test kit when the water looks like the OP's?
    42' natural free-form pool, vinyl lined, 6' deep end, 21,400 gallons
    2 HP Hayward Superpump, Hayward Aquarite SWG, AquaComfort 125k btu heat pump, 350lb Hayward Pro Series sand filter
    2 skimmers, 2 floor drains, 10 returns (6 in the pool, 2 in the steps, 2 in the swim-out)
    TF-100 Test Kit
    Jun 2014
    15,205
    Re: Green pool
    Which test kit are you referring to? That may help.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Green pool
    Quote Originally Posted by s1njin View Post
    Two things: 1) in the sample tube, it doesn't look green at all. Compare the images in posts 24 & 34 in this thread Helping a friend: This should be a good one - Page 2
    2) The FAS-DPD test kit we recommend - the only test that will read the FC levels high enough to kill that algae - turns Barbie pink with the first reagent and the second one turns it clear. So even if it did have a pale tint, it would be obvious.
    Back to pool school to learn about test kits
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,575
    Re: Green pool
    HI!!!!!!!!! What you do not like split pea soup??? LOL Sorry I had to
    We can help you get that pool looking like a jewel. You have to help us help you though. Please get a good test kit. For that "yummy" looking pool you will need the XL.
    Let us know when your test kit gets there and we can walk you though it!
    Kim
    Jun 2015
    Jackson, NJ
    123
    Re: Green pool
    I've never tested water that looked like that, so I really didn't know what it'd look like. I DO know how to test my water.
    TF-100 Test Kit
    Jun 2014
    15,205
    Re: Green pool
    Samantha, are you using the Taylor K2006 test kit? It has the powder agent that makes the water pink (one scoop), then you use the R-0871 drops to make it clear? Or are you using something else? That wasn't clear to me in this thread, so I would like to confirm.
    Jun 2015
    Southdeerfield, Ma
    3
    Re: Green pool
    I don't have a test kit.... I brought it to a pool company and had them do it.
    May 2014
    Franklin, NC
    9,189
    Re: Green pool
    Quote Originally Posted by Samantha11892 View Post
    You need your own test kit. Order a TF100 and at least include the XL option. That will give you what you need while you are clearing the pool, and probably enough reagents for a couple of years normal use.
    The only other real option for a test kit is a Taylor K-2006. Be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles. Yo need to get the K-2006-C to get the larger bottles that you want. Even then it is a little short on the reagent & powder for the FAS/DPD test.
    I also have the SpeedStir and Sample Sizer. They speed testing and accuracy.
    Support the site
    Jun 2015
    Southdeerfield, Ma
    3
    Re: Green pool
    I just ordered that. In the mean time what should I be doing so it doesn't go back to how it was ?
    Jun 2014
    15,205
    Re: Green pool
    Not a lot unfortunately. You could add a gallon or so of bleach just to try and maintain the status-quo, but you can't effectively manage the "SLAM" and clear the water without the kit. All you can really do right now is read-up on the SLAM (link below) and start buying several gallons of bleach. You'll need quite a bit.
    When you get your test kit, there's two things you need to check before starting the SLAM: CYA = 30ish and PH at 7.2. Once you are there, let us know and we'll walk you through the SLAM.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,111
    Re: Green pool
    The biggest thing you need to do is clean as much gunk out while you wait. The more you get out now, the faster the SLAM should be. That and read, read, read.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
