Results 1 to 10 of 10
Thread: HELP! Unknown pipe fitting in my pool
    gq_wolf's Avatar
    Jun 2015
    ROWLETT, Texas (Dallas)
    25
    Need some help with an unknown "hole" fitting in my pool. We bought a house that came with a pool, but the owners had already moved and did not give us any instructions on operating the pool. A lot of it I had to figure myself. One thing that I have not figured out is this threaded opening towards the shallow end of my pool (see pictures).
    The issue I have is that debris finds a way to build up in here and I need to know if this is something I can plug. I assumed it was something to maybe screw a pole in? Upon draining my pool and cleaning this out, it appears the pipe goes down deeper and may be a part of some piping system. I have no idea.
    If someone recognizes this and could offer an explanation, I would really appreciate it.
    Thanks!
    May 2015
    Chickasha, OK
    184
    Re: HELP! Unknown pipe fitting in my pool
    Could it be part of an in-floor cleaning system? A quick Google search turned up this image:
    Do you have any pool "accessories" that look like they thread into that fitting?
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    22,553
    It looks like a regular eyeball fitting to me. Maybe for a fountain.
    gq_wolf's Avatar
    Jun 2015
    25
    No accessories that I am aware of.
    I have a dolphin spitting fountain above ground.
    Jun 2015
    Lehigh Valley, PA
    7
    Could it be a floor inlet? My pool has several of these which allow the water returning to the pool to be circulated from the bottom as well as the top returns. I'm also thinking it could be a pressure plug. According to our PB, those are used when the pool is empty to relieve pressure in case water builds up under the gunite. It helps prevent water from popping the pool out of the ground. Do you have a valve on the return side that may connect to this fitting?
    24,500 gal free form gunite, 3' - 8', Intellichlor IC40, Intelliflo VS pump, Sta-Rite S8M500 cartridge filter, Sta-Rite Max-E-Therm 400 heater, EasyTouch automation w/ Screenlogic interface, Aquabot Rapids 4wd cleaner. Taylor K2006 test kit.
    gq_wolf's Avatar
    Jun 2015
    25
    Quote Originally Posted by rps View Post
    Since debris can collect in here, I don't think it would be an inlet.. unless there is a setting/valve in my pool equipment area that I don't know about. I don't know if there is a valve that connects to this.
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    I was going to ask if it was a hydrostatic valve?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Is there some reason you can't run a garden hose down it and see if water appears somewhere else?
    gq_wolf's Avatar
    Jun 2015
    25
    will try that this evening.
    gq_wolf's Avatar
    Jun 2015
    25
    Didn't notice anything coming out of the jets when putting my water hose in the orifice. Looks like COBrien was right. I spoke with my local Leslie Pool repair guy. He said that for some of the older pools, this was installed with a fitting much like a sprinkler head that would act as a jet return. Perhaps the owner decided to upgrade their system - making this obsolete. I've never seen or felt water being suctioned or jetted from this hole, so it kinda makes sense. He told me that any plumbing store should have a cap that would thread into it.
    Thank you all for your thoughts and responses. This is a great site with friendly advice.
    Thanks!
    **33K free form IG plaster pool, pentair FNSP 60 Plus - DE, 1.5 HP WhisperFlo pump, 120V American Products pool light, Taylor K-2006 Kit, and proud new owner of Dolphin A30i**
