Thread: Cutting wall for another return.
    Jun 2015
    NJ
    2
    15x30 AG. Has anyone cut into aluminum wall for a new return to improve circulation? This would be in wall section opposite/diagonal to current skimmer/return location. Circulation farthest from original return in this area has yielded some algae. Pool owner for 15 yrs.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cutting wall for another return.
    Try using the search box in the upper right for "adding above ground return". This thread might have some tips: Installing second return question
    Isolated Spa - 345 Gallons
    Jun 2013
    Erie pa
    68
    Yes i did with my old pool and it worked fine.but i did it before i put the liner in.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
