Thread: Taylor #9198 Test Tube
    JoyfulNoise's Avatar
    May 2015
    13,249
    Question Taylor #9198 Test Tube
    The Taylor #9198 test tube has multiple graduations on it for different sample volumes. On the FC/CC tests one uses the 25mL mark for 0.2ppm/drop resolution and the 10mL mark for 0.5ppm/drop. Does anyone know what the test resolutions are for the other graduation marks?
    The FAS-DPD test is easy because the DPD powder amount does not have to be exact (just saturate the solution with indicator dye). The TA and CH tests would be harder to change as the other reagent and indicator drop count would need to change for different sample sizes.
    Thanks!
    Matt
    22,553
    Re: Taylor #9198 Test Tube
    Those aren't necessarily for other resolutions. They're for different tests altogether. If you're extremely curious you can go to Taylor's site and look through all the different tests they offer and what the sample sizes are.
    May 2015
    13,249
    Oh I know they're for different tests. I was just curious about using them for the FC/CC tests as the different volumes of test water will produce different titration drop resolutions. I thought the math would have been worked out and was hoping to not reinvent the wheel.
    Matt
