Thread: Deck Plans for an 18 foot AGP
    Jul 2014
    South Bound Brook, NJ
    9
    Hey folks,
    Been thinking a lot about putting up a small deck for my pool. I have been searching for deck plans but can't find a single one. The deckplans.com site is not giving their plans away anymore. Does anyone have a copy that would fit my needs? Nothing special, just steps up to a small landing. The landing just needs to be big enough to fit a pool box on it.
    Thanks in advance!
    Sean
    7500 Gallons, AG, Sand Waterway 22" with 150 pounds of sand, 1HP pump, Installed June 2013.
    Painted the walls on the sun side black. Warmed up the pool super quick.
    Cypress, Tx.
    154
    Re: Deck Plans for an 18 foot AGP
    I made a deck plan that goes around the pool and up to part of the pool that was an extension of my existing deck.
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    Jul 2014
    9
    Very impressive! No, just a small landing with stairs.
    AprilsZoo's Avatar
    Jul 2013
    100
    Try https://www.decks.com/deckplans/Medi...on_Decks/1L056
    None are specifically designed for pools, but we are planning to adapt the one I referenced above, by using just the lower portion that leads to the small landing. I think we will have to add a couple steps, too... I haven't studied the plans that closely yet, but extending the stairs portion should be easy enough, and then making the minor changes to the deck legs to add the extra height of the added steps.
    It's a place to start...
    You do have to give them some info like email addy, etc. There are other plans on the site as well.
    Another option... I'm told that some big-box stores (Lowe's, Home Depot, etc.) will create a deck design for you, when you buy the materials from them. You need to know the measurements of how high you need the finished deck to be, and the dimensions of the landing you want. Specific #'s, measured from the ground to the top of the pool, at the spot you want the deck to go, and the exact dimensions (footprint) of the items you want the "small landing" to accommodate ... From there the software they use should be able to make the adjustments to hug the pool shape, if that's what you want.
    Good Luck,
    April
    🌵 April 🌸
    Some of my posts may be long... but they're *always* worth it! 🙃
    👙 Intex UltraFrame 21' x 52" {~10,000 gal.} 🐠 Krystal Klear 16" Sand Filter 🐳 Pentair Intelliflo 1.5 hp Variable Speed Pump🐬 Borates @ ~50 ppm 🐚 Taylor K-2006 test kit & SpeedStir🌀
