Results 1 to 17 of 17
Thread: Brand new pump stopped working
    Jun 2015
    Clinton, Utah
    57
    We just bought and set up our pool this weekend, I had left the pump running overnight as per the instructions for our SWG, and when I got up this morning the pump was not working. It was the basic pump that came with our pool, I'm trying to contact Coleman, but what should we do in the meantime? Should I keep the kids out until the pump is replaced?
    Will we have to start all over with the salt we put in the pool of it takes a few days to a week to get a new pump?
    Coleman 16'x48" AGP, Pump is what came with the pool 1,000 gallon pump I believe with Cartridge, SWG Intex brand Krystal Clear
    First Year Pool Owners
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Brand new pump stopped working
    If you could link the pump or item you purchased that would be helpful.
    Is the pump plugged into a GFCI outlet? Did it get tripped off? Is there a reset/GFCI built into the pump set up?
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Test and add chlorine/bleach to the target level for your CYA, brush the pool to mix it wait 20 min and the send the kids into the pool to mix it more.
    Use the Pool School - Chlorine / CYA Chart to determine you FC level.
    Use Pool School - PoolMath to calculate how much to add.
    it is important to keep the chlorine level above the minimum level at ALL times to keep your pool sanitized and algae free. Aim for target or 1-2 ppm higher and test daily. Especially until you are familiar with your pool and its chlorine consumption.
    Mar 2015
    Harvey, LA
    300
    Keep in mind when your pump isn't running, the salt chlorine generator isn't working too...so you'll have to dose the pool manually with chlorine until you get it going again.
    Try the simple things first...have you plugged something else into the outlet where you have the pump plugged in? Have you plugged the pump into a different circuit? GFCI or simply a tripped breaker could be the issue, especially if you're running the pump via an extension cord.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Jun 2015
    Clinton, Utah
    57
    We are using an extension cord right now, I haven't tried plugging anything else into it. I will do that now! I checked for tripped breakers and tried to reset the pump. Hopefully when my hubby gets home we can figure it out. I added my cya last night and will add more chlorine today as it was only at 2ppm last night. Thanks for your help everyone! I honestly do not know the brand of the pump...it's the pump that came with our Coleman 16x48 pool
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    If you do have to contact Coleman I hope you have an easier experience than I had with Intex.
    Intex Ultra Frame 20'x52" pool (10,600 gallons); Sand filter (Model SF80110); Krystal Clear SWG (Model CS8110); AquaBot PoolRover Jr. Pool Cleaner; TF-100 Test Kit with SpeedStir
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    My advice is to throw that pump in the trash and pick up one of these: Walmart: Intex Krystal Clear Sand Filter Pump
    It's a straight drop-in replacement for the Coleman that came with your pool, which was undersized to begin with.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Coleman has a video on their website on setting up the pump/filter, the Sand Filter Round Frame video. You might want to watch it to make sure everything was put together ok. Coleman Above Ground Pools
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    Jun 2015
    Clinton, Utah
    57
    Update:
    It's not the pump...it's our electrical outlet, but it's looking like it had something to do with the pump running and possibly the sprinkler system going off. I'm not sure at this point, but we have several outlets that are now not working. the breaker looks fine...not tripped.
    So, Jeffchap, how do we know if we have an undersized pump? Are most pumps that come with the pools undersized? We just paid 179.00 for the SWG....I'm gonna have to wait on a better pump for awhile.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    The rule of thumb used to be whether or not it was enough to turn over your pool x times per day (2 times, 4 times? I don't recall). If your pool is 5000 gal, your pump will turn it over almost 5 times per day provided you run it 24x7. But most people don't want to do that.
    But the old rule has fallen out of favor, and most folks just base it upon whether or not it keeps your pool clean enough. My first metal frame Intex was 14'x42", and I used the cartridge filter it came with for a while. Buy it didn't stir the water up too well and I always had a lot of sediment on the bottom to sweep up every day. Oklahoma is very dusty in the summer. Once I swapped it out for a larger pump, it stayed a lot cleaner.
    But my biggest reason for the swap was to replace the cartridge with a sand filter. It seems like I was always rinsing out or replacing cartridges, and the sand is much more maintenance free. Backwash a couple of times per season, and that's it. And I don't even mind the backwashing. It's kind of fun to see what comes out of it. I know, I may need professional help....
    You may find the standard pump works okay for you. But most people feel they are jst about the minimum size you would want for the pools they come with. Worst case is you may have to vacuum and skim a little more. Try it and see. If it works for you, stick with it. You can always upgrade later.
    Pentair IC40 SWG
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Even if the breaker looks like it's not tripped, did you flip it ALL the way to the off position, then back into the on position? Sometimes they need reset even if they don't look tripped. Also, when you do that, be sure take the load off of it, like don't plug the pump in, while you're testing. You may need to replace that breaker.
    Aquapure SWG
    Jun 2015
    Clinton, Utah
    57
    My Pool is a little over 5,000 gallons. I really do not want to have to run my pump 24 hours a day! :/ What size of pump should I get if I decided to invest in a sand filter pump?
    Jun 2015
    Clinton, Utah
    57
    My Pool is a little over 5,000 gallons. I really do not want to have to run my pump 24 hours a day! :/ What size of pump should I get if I decided to invest in a sand filter pump? Would a 1200 GPH Sand Filter be sufficient? This is the one I was looking at: http://www.amazon.com/Intex-Sand-Fil...lter+Pool+Pump
    Sandra- We actually found out last night that all of those outlets were on the same circuit and it tripped the GFCI outlet in our garage....after we replaced the breaker LOL! We are good to go now!
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Glad you found the tripped GFCi. I remember when that happened to me once....something wouldn't work and I finally figured out it was the tripped GFCI in the bathroom, far from the problem outlet! The pump you linked looks good....it says "Pump Flow Rate: 3,000 gph (11.3 m3/hr). System Flow Rate: 2,450 gph (9.2 m3/hr)"; I'm not sure which number to use for the gallons per hour (gph), the 3,000 or the 2,450, but say it's the 2,450. It will take it 2 hours to filter your entire pool water of 5,000 gallons through the pump/filter. If you want it to flow through 3 times per day, a good rate, that's about 6 hours run time on the pump. Sounds very reasonable. I have a sand filter and love the low maintenance of it.
    Aquapure SWG
    AprilsZoo's Avatar
    Jul 2013
    100
    I know this thread is older, but:
    Don't forget though that with the SWCG, you may end up needing more than 6 hours run-time to generate enough chlorine... It all depends on whether your pool is in the sun all day, what your CYA level is, and how much use it gets, and when.
    In sunny AZ 6 hours of run-time probably wouldn't be enough to keep chlorine in the pool at safe levels for the other 18 hours of the day, even at that turn over rate.
    You have to experiment with how long to run the pump & SWCG, and at what time of day... If you do most of your swimming in the late afternoon or evening, running the system in the early morning, or overnight might not work best, because by the time people are getting in FC could be zero, which wouldn't be safe and sanitary ... even if it managed to keep the algae away.
    We had to use trial and error, and lots of testing .. to work out when to run ours.
    My dh and kids used to tease me about getting out my "chemistry set" with all its "tubes and beakers"... They even called me a "pool nerd"... Until I pointed out our pretty, sparkly water... And the laughing stopped. (well, at least about that).
    🌵 April 🌸
    Some of my posts may be long... but they're *always* worth it! 🙃
    👙 Intex UltraFrame 21' x 52" {~10,000 gal.} 🐠 Krystal Klear 16" Sand Filter 🐳 Pentair Intelliflo 1.5 hp Variable Speed Pump🐬 Borates @ ~50 ppm 🐚 Taylor K-2006 test kit & SpeedStir🌀
    May 2016
    Forest Hill, La
    3
    I have this pool and as the pump that came with it is very inadequate.. I'm wondering if this will work for this pool : Intex Krystal Clear 3000 GPH Above Ground Pool Sand Filter Pump - 28651EG - Walmart.com
    I'm wondering if the adaptors for hoses and etc will be the same. Also, how long should we run this? New to all of this! Thanks!
    May 2016
    Forest Hill, La
    3
    Did you go with this pump? I'm trying to convert and looking at same one!! I have the coleman 18x9x48
