Results 1 to 9 of 9
Thread: What time of day should I be testing my chemicals?
    Jun 2015
    Jackson, NJ
    123
    Given I have a SWG which only makes chlorine when its on, what time of day should I be doing my full battery of tests? If I test at the end of a swim day, won't I get skewed results given bather load and sun? If I test at the beginning of the day, my SWG hasn't been running all night making any chlorine.
    So - do most of you split the difference and test midway through the day? W/ people in the pool and whatever is going on?
    Thanks !
    42' natural free-form pool, vinyl lined, 6' deep end, 21,400 gallons
    2 HP Hayward Superpump, Hayward Aquarite SWG, AquaComfort 125k btu heat pump, 350lb Hayward Pro Series sand filter
    2 skimmers, 2 floor drains, 10 returns (6 in the pool, 2 in the steps, 2 in the swim-out)
    TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Re: What time of day should I be testing my chemicals?
    Better to test early evening when you can UP your FC if needed and have it sanitizing all night without loss to sun effects.
    Jun 2014
    15,192
    Woody already answered, but just in case you didn't see it, below is a link from the Pool School page that discusses that issue quite a but and confirms that response. Have a great day!
    TFPC for Beginners
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you're running your SWG during the day and it's off at night, then the evening is actually the BEST time to test. You'll know for sure then if your FC has dropped too low due to bather load/sun and you can remedy that with increased FC (either more run time or supplement with liquid shock/bleach). That way you don't have a potential problem brewing over night that your SWG can't overtake the next day and you know that you have sufficient FC overnight to keep things sanitized without loss to bathers or sun.
    Isolated Spa - 345 Gallons
    Jun 2015
    Jackson, NJ
    123
    Excellent. Thanks much !
    TF-100 Test Kit
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    +1 with Woodyp
    Solar Blanket, Well Water, Borax Added. 68
    Jun 2015
    Jackson, NJ
    123
    I understand the concept, but what about CC? If I test at the end of a hot day where I've had a lot of people in the pool, doesn't it stand to reason that I might flag some CC in it? I have never had CC in my pool, yet yesterday evening I registered .5 after 2 days of 90 degrees both in the pool and ambient air and 1 day of 6 people in it.
    TF-100 Test Kit
    Feb 2014
    Central Minnesota
    5,080
    If it's a hot day with lots of sunshine, you won't have CC showing up unless you have an active algae growth problem or your FC got to zero during the day and your SWCG isn't keeping up. For instance, 0 FC, 1 CC. Sunlight is very good at breaking down CC so as long as you have adequate FC, CC will dissipate quickly. This is why CC is a good indication whether or not something is up.
    Jun 2015
    Jackson, NJ
    123
    So I guess when I get home I'll test the water and see how my goosed CL load did. Really nothing else to it at that point.
    TF-100 Test Kit
