Results 1 to 12 of 12
Thread: Coleman vs Intex
    May 2015
    Chicago, IL
    508
    Coleman vs Intex
    Wondering if anyone here has used Coleman and Intex pools, and if there is any disadvantages with a Coleman.
    I put up a Intex two weeks ago, and now there is a leak somewhere in the bottom.
    So I am thinking on switching to a Coleman, cause I figure Intex is going to give me grief on replacing it. Even if they don't, and decide to replace it, from what I understand, you have to send them the label cut out of the liner, and then they will send you a new one. So who knows how long this will take. I am impatient and like my things now, not at their leisure.
    So I am thinking to get a Coleman but I don't know anyone that has one.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: Coleman vs Intex
    From what I have heard, Coleman is just a rebranded Intex.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    No, it's a rebranded Bestway. I've had both, stick with Intex unless you want a different tile pattern.
    May 2015
    Chicago, IL
    508
    So, only the tile pattern is different? How about liner thickness?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    The posts of the Coleman brand appear to be thinner. I don't know if it means they are weaker, but they are noticeably thinner.
    30,403
    My only familiarity with intex is what I read on this forum. Basically, having one is a PITA. The pumps are woefully underpowered and the filters are too small from the git-go.
    So, what we see is people buying an intex and then starting to upgrade to satisfactory equipment. Then the real rub comes in when you find out that Intex tries to make everything proprietary so you cannot use good quality equipment.
    I know the entry price on Intex is good but, from what we read, you pay later for that good entry price.
    There are other members here who have hands on experience with them and I would put a lot more weight on their opinion than mine. Mine is just an overall feeling I get from reading about them the last 8 years.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    I've been completely satisfied with the Intex's I've owned. Granted, I did upgrade to a sand filter, SWG, and a Hayward skimmer. But a piece of PVC and a hose clamp is all I've needed to adapt the Hayward to the Intex fittings. All the rest of my plumbing is Intex, end to end.
    I looked into putting in a "real" AGP last year, but for the cost, I could put in a new Intex every couple of years for the next decade and still come out ahead, given that I already owned the sand filter and SWG.
    BTW, the plumbing on the Coleman is compatible with Intex, so you can interchange pumps etc.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Apr 2014
    Manitoba, Canada
    70
    After one season with our Bestway branded pool (now sold by our local Canadian retailer under the Coleman name), I have to say we are more than satisfied with the quality. It's important to add that although we live in an extremely cold climate (and should have disassembled for the winter season) we chose to leave our pool up throughout the winter, and to our surprise and excitement not a leak to be found come spring. We had concerns about jeopardizing the integrity of our liner with the use of our electric heater (that keeps our pool at around 90 degrees on any given day), but came through our first season and now almost a full month into our second without any problems whatsoever. We invested heavily in an upgraded pump and sand filter as well, and had our pool professionally hard plumbed and wired. You can follow our build by clicking on the link in my signature. Good luck and have an awesome summer
    Our "Backyard Oasis" 2014 12x24x52" Steel Pro Hydro Force (Bestway) 7725 gallons; Jacuzzi 1LRC-5-S1/B 1HP Pump: Jacuzzi L192-7C 19" Laser Series Sand Filter; KStar 10 10KW Electric Pool/ Spa Heater; Jacuzzi wall mounted skimmer
    May 2015
    Kentucky
    2
    I aslo have an Intex and I think it is better than Bestway
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I think the ultra frames are actually pretty good. I know of two that have lasted 3-4 plus years, even being left up over the winter for their life cycle. One, at a house, I could not afford save an unexpected windfall of serious cash.
    Essential Links:
    geegaw's Avatar
    Aug 2015
    Texas
    330
    My INTEX has lasted 7 years. But will be getting a bigger one at the end of season. My problem is my store only carries Colman now. I can order Online if I need to. But INTEX is now more than twice as much as Colman! !
    I'm looking for 18' x48" my store has that in a Colman for 344 now on sale. The INTEX same size online walmart is 844. Which is better ??
    Everything INTEX, 20 x 48 , AG, 8362 gal. although its only 90%full. well water, pump 2500gph intex, bleach 10%, and Taylor test kit.
    Jul 2012
    SE Minnesota
    137
    Walmart is only 444 for 18x48.
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
