Results 1 to 9 of 9
Thread: Anyone tried Cool! from Encore Coatings?
    My deck is KoolDeck and it's spalding and cracked. I've got someone coming out to level the deck and then I want to recover it, preferably something I can roll on. I found this Cool! product online but am having trouble find pictures of where it's been used, but all reviews I find are positive. Anyone had experience with it?
    18x36 IG Vinyl, ~22,000 Gallons, WhisperFlo 1HP, Hayward 300 LB Sand Filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Anyone tried Cool! from Encore Coatings?
    Welcome to TFP,
    Cant say I have, but someone around here may have used the product. Good luck on your project, and enjoy the forum.
    Essential Links:
    tnmasterplan's Avatar
    Apr 2014
    West Monroe, LA
    13
    Bump! I am also looking at something to put on my concrete deck around my pool.
    Louisiana - 19,000 gal, Free form Gunite / Quartz Plaster, Flagstone Waterfall, Cartridge Filter, 1.5hp Hayward Pump, additional pump for waterfall. - Just purchased the Taylor K2006-C Test Kit based on feedback
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    I haven't used it, but was considering it for our upcoming pool deck. The reviews on Amazon seem good, and when I asked a question there someone responded with their positive experience of 3 years.
    There is a negative review on YouTube if you haven't found it already, with a guy who used the product in a similar situation to yours. You might want to look into it. I don't know the veracity of his claims, but the company does seem to admit that the product can't reduce temps as much when applied over an existing product layer (as opposed to over regular concrete) because the first product acts as a barrier to the "heat sink" action. They do say that it will maintain at least the same temperature as the original Kool deck surface. Cosmetically, I'm not sure how it works over something like Kool. That's where this guy had a gripe, but the company claimed he didn't prepare the deck properly or something.
    I too am interested in firsthand experience with the Cool! product. This is just what I've learned from my own research so far. I hope it helps.
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    JamieP's Avatar
    May 2011
    1,135
    I just found this helpful link from this site that gives a positive review from one guy's professional experience: Encore Cool Pool for Concrete Decking
    I hope it helps. I think I'm really leaning towards using this product. It has the benefits of being cool, I can make it any color I want, and I can easily make my existing patio match the pool deck.
    JamieP's Avatar
    May 2011
    1,135
    Does this make sense...
    Someone online is claiming that this product is only a gallon of concrete adhesive and a small bag of white sand mixed in a five gallon bucket with a gallon of latex paint (which the instructions say you will need to buy), and therefore is a huge ripoff and you can make it just as easily yourself.The instructions from the company to ensure you get the warranty is to properly prepare the concrete with some sort of etcher/cleaner that they sell, apply two coats if the product, then 2 coats of sealer.
    My question would be, if this is all that the product really is, would it actually give the 38% cooling reduction that they say?It's supposed to act as a "heat sink" so the paint color you choose isn't supposed to matter. Would with above products do that?
    I'm willing to entertain that there is more to the product than the above person claims, but since the instructions emphasized the proper preparation of the concrete so much (to the point where the lady at the company told me I'd even need to use the concrete cleaner on brand new concrete), not to mention to the two coats of sealer, is that more of an indication that the product isn't as special as it seems?
    Just looking for people's best opinions based on experience working with other concrete surfacing applications. I know not many people here have actual experience with this product, but you may understand some of the principles involved more than I do.
    Thanks!
    Here is the product link for your reference
    Cool Pool Decks | Concrete Cooling Coatings | Encore Coatings
    Last edited by JamieP; 08-14-2015 at 10:08 AM. Reason: Added link to product description
    Mar 2016
    Marrietta Ga
    82
    Did anyone try this? I am talking to a professional installer and thinking about having it done. He did say if you don't grind down to raw concrete the cooling part doesn't work
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    What is your current concrete surface that you mention grinding down?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jan 2016
    Mesa, Az
    541
    A lot of installers use a grinder (looks like a terrazzo grinder) to prep the existing concrete for topping with various materials. I'm guessing (because I'm not an installer) that this removes the top 1/16 - 1/8 where most of the contaminants (dirts and oils) would be. Also the surface is almost always the weakest area in the slab, due to improper finishing techniques. When this isn't done, I've see plenty of floors, garage floors in particular, suffer coating delamination within a year.
    17' x 30' rectangle pool, two 7' x 7' baja decks, 6' x 8' raised spa. Hayward 2HP VSP for features, filter and returns. 2HP single speed for 9 spa jets. 1HP blower for spa bubbles. In-Floor cleaning, Cartridge filter, AquaConnect automation, 400K BTU NG heater. Plaster is Stonescapes mini-pebble in Aqua Blue + abalone shell TF-100 Text from Neighbor -- They're digging your pool!
