Results 1 to 13 of 13
Thread: Going through 5ppm FC / day?
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    My pool seems to be eating Chlorine to the tune of close to 5pmm per day... is this normal?
    My numbers for today were as follows...
    7AM
    FC - 7.2
    CC - 0
    PH - 7.4
    TA - 100
    CH - 60
    CYA - 50
    Temp - 75f
    6PM
    FC - 2.4
    CC - 0
    PH - 7.4
    TA - 100
    CH - 60
    CYA - 50
    Temp - 81f
    The temp is the water temp, not the air.
    According to Poolmath, I needed to add another 120oz of 8.25% bleach to get it back up to 8ppm.
    I have had 0 drop in FC during the overnight hours.
    I started out with less than 20ppm CYA last week, and added some on tuesday per poolmath, and am now reading 50. I had thought that once I got the CYA in there, I should end up with less loss due to the sun, but I'm going through the same... if not a bit more to hold the higher FC levels that 50pmm CYA needs.
    I run my pump 24/7 on low (if that makes a difference).
    Am I missing something?
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2014
    15,192
    Re: Going through 5ppm FC / day?
    By any chance have there been any significant changes in water (i.e. rain water exchange/fill)? Any unusual load in your pool that may have caused the FC to work harder than expected (i.e. lot of swimmers, any tree debris, etc)? Just trying to eliminate any obvious causes since your test numbers do look quite solid.
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    The weather was 97f and sunny today, the only person in the pool was my wife floating around for an hour or so this morning (She also vacuumed the pool through the filter).
    I have not had to add any water to the pool since the last backwash (yesterday).
    The pool is crystal clear (no debris).
    Jun 2014
    15,192
    Others should chime-in shortly, in the meantime, consider reading this link about a previous thread there in AL:
    Daily FC loss
    Check back to see if any other TFP'ers have replied.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,631
    How are you testing----what test kit?
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    I'm using the K-2006 test kit that I have listed in my signature.
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    ok... having gone through 120oz/day of 8.25 for the past week, I have decided to try raising my CYA to 60, and see if I end up with better FC numbers throughout the day. Hopefully the CYA will do its job, and I end up using less bleach.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Have you considered doing an overnight chlorine loss test to rule out yet unseen algae?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Apr 2010
    East Texas
    9,631
    I'm willing to bet that at BEST...........you only reduce your FC loss by 1ppm. I'll be more than interested to know.
    May 2015
    Paxinos PA
    57
    Hmmmm, just coming off a SLAM, I was excited to have "only lost" 4ppm from 530AM to 9PM. Maybe I shouldn't have been so jubilant?
    22,000 gal 16x34, IG, vinyl (7/14)
    DE Hayward Perflex extended cycle
    Hayward Super Pump
    Aquacal heat pump
    TF-100 test kit
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    I have had NO overnight loss for the past 2 weeks (I test every morning, and evening), so I know that it's the sun that's doing it, plus the fact that I have had 0 CC for the same time period clinches the fact that I don't have any algae.
    Unless I'm missing something, which is always possible.
    Mar 2007
    San Rafael, CA USA
    12,082
    You can do an OCLT with the pump running at night to confirm that the consumption isn't something related to circulation such as in the filter or piping or some system that is only on during circulation (e.g. ozone or UV). If the OCLT passes, then you are right that it's related to sunlight so the CYA test reading is suspect or something very weird is going on.
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    My pump runs on low 24/7 during open season, and I get 0 loss overnight ... am in the process of SLOWLY bumping my CYA up. I have some trichlor tabs left over from last season... I'm using them to bump the CYA, AND hold FC for me.
    I'll report back once I reach my 60 mark for CYA, and let you know what my results are
