Results 1 to 11 of 11
Thread: Cannot upload pictures
    Jan 2015
    Arkansas
    35
    Not sure what I am doing wrong, but when I try to attach photos, I get a box pop up to upload pictures from my computer. It only let me upload two and then I get red exclamation marks by the rest. It says I have used 248 of 250 MB allowed. I don't get what I am doing wrong. Is there an easier way to insert pictures? (And yes, I reduced the size of all pictures before trying to upload them.) This is super frustrating.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: Cannot upload pictures
    You get very limited space here, even if you're a supporter. Best bet is to use some photosharing site and post the links in the thread. Posting Photo's Tutorial
    Jan 2015
    Arkansas
    35
    Thank you so much - that was so frustrating. Wonder why they limit the size when pictures are so encouraged? Going to try a test run in the test forum.
    May 2015
    Chicago, IL
    508
    Well it is because pictures take up a lot of database space. On image sharing sites such as photobucket, they are designed for that. This site, while photos are encouraged, it has to have a good balance between images and forum functionality.
    Jan 2015
    Arkansas
    35
    Makes sense and was pretty easy after following the instructions.
    Can't upload small jpeg pics from my computer (approx 50k) any problems with the sites photo upload feature currently? I used to be able to upload this way.
    24K gal, plaster, concrete decking, cantelivered coping, 20 years old, raised attached stone spa - 1 1/2 HP purex triton pump, 3 yr old 48 sq ft Pentair DE filter with multiport, Polaris 380 w/pump, 2 yr old Pentair mastertemp 400k heater - live in southeastern PA outside phila.
    May 2015
    Chicago, IL
    508
    It's possible, cause I still don't have all the little bugs (well not bugs, but set up fully) worked out on the new server just yet. So for now I would use a picture hosting service (like photobucket) and post them from that.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Quote Originally Posted by jp4120 View Post
    the limit is in totality for your account. If you have hit the limit, no matter how small you will not be able to upload more without deleting previous uploads.
    The best option is to follow the instructions Rixhard linked in his post.
    Support the site
    May 2015
    Chicago, IL
    508
    Well Tim, there is a issue with the flash uploader, so I have changed it from that to the ajax uploader for now. so they can post images again if they are not going above their limit.
    works now so whatever you did fixed it...thanks
    May 2015
    Chicago, IL
    508
    Good to hear.
