Results 1 to 17 of 17
Thread: Water slightly cloudy
    Apr 2014
    Stony Brook, NY
    159
    My water is very slightly cloudy. My wife thinks I'm nuts, but I see it. All levels are perfect, no chlorine loss, so I'm not fighting an algae problem. My pump runs 6 hours a day. I'm thinking maybe a backwash, and new fill with de are in order????? Any other ideas?
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    Jun 2014
    15,059
    Re: Water slightly cloudy
    Hard to tell. Backwash? Perhaps. Any chance you could post all of your test numbers for the crew here to review? Also let us know which test set was used? Sometimes that answers a lot of questions for us.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Backwash couldn't hurt ---------when is the last time you did?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Is the pressure up 25% from clean pressure? If not then just add the DE?
    Apr 2014
    Stony Brook, NY
    159
    FC 4 ppm
    PH 7.6
    TA 60
    CYA 70
    Salt 3000 ppm
    Taylor tf100 kit
    I haven't backwashed since pool was opened in beginning of may, but my pressure hasn't increased at all since. I'm just thinking maybe the guys who opened, didn't put enough de in?? So maybe a backwash to clear, then add proper amount???
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    How often have you been testing your chlorine? While 4 isn't technically below the minimum CL with CYA of 70 in a salt pool, your target is 5. If it could have been dropping lower when SWG is off, you COULD have the start of algea.
    I know I'm in a different climate with 100 degree days with sun and 90 degree water, but I can almost COUNT on issues with my water if I drop below the TARGET level. I'm also at 70 CYA and I'm still targeting closer to 8 with my SWG. I've fought algea enough with SLAMing my pool and just know how it behaves. I get critters in the skimmers overnight dead and alive (even rodents) so I'm way more comfortable targeting the higher number of the non SWG to compensate for those unknown chlorine consumption risks.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    DFW, TX
    24,483
    Yep, +1 on what AimeeH says. I have CYA of 70, SWG and also target 8 FC. I would go higher if the PH test worked. But, my PH rises too fast to risk not testing it at least weekly. I've been working a little algae problem since Saturday after the kids swam for hours everyday and the water was 88-90. And my water did not cloud, I just have a dozen or so algae spots.
    I like your idea about backwashing and adding DE.
    Apr 2014
    Stony Brook, NY
    159
    Guess I will bump the chlorine levels up, AND do a backwash and de add.
    Apr 2014
    Stony Brook, NY
    159
    Another side note....my cc is zero...doesn't that indicate nothing is going on????
    Jun 2014
    15,059
    Actually no. Other threads on this subject confirm that you can have a CC of zero but still have an algae issue. That's why other factors (i.e. OCLT) are used in concert to base a decision.
    Here's on example: Algae detection?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    I've never had CC reading in my pool. Even when fighting visible algea spots.
    DFW, TX
    24,483
    I had 0 CC last Saturday and Sunday and some algae spots due to low FC. 0 CC is good, but really more than 0.5 CC indicates that something is going on.
    Apr 2014
    Stony Brook, NY
    159
    A little update. I redid tests.( Sunday when I did them, I just finished a 6pack of sam adams west coast IPA!!!)
    FC 4 ppm
    PH 7.6
    TA 80
    CYA 50
    Salt 3000 ppm
    Apparently my CYA is pretty low. Im bumping that up, along with a backwash, refill of DE, then a slam. 2 hours later, my pool looks almost perfect!!! I am going to get all levels in line where they should exactly be, along with increase my VS pump run time. I was only running it 6 hours a day. Gonna bump it up to 8. I will update in a couple of days.
    DFW, TX
    24,483
    Good plan, maybe move the sam adams to after testing.
    Apr 2014
    Stony Brook, NY
    159
    Quote Originally Posted by pooldv View Post
    Lol! Last update.....all levels are perfect, and water is so clear and sparkles like a diamond!!! Now I just need some sun. Cloudy all week, this weekend gonna be a rainout. Bummer.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    LOL So YOUR jewel like pool is why it is going to rain up there???
    Of course it is going to rain all weekend when your pool has it sparkle back!
    Kim
    Apr 2014
    Stony Brook, NY
    159
    Quote Originally Posted by kimkats View Post
    Kim
    Maybe i should make the pool cloudy again, and the sun will return??? LOL.
