Results 1 to 7 of 7
Thread: Got my new pool up and opened
    This year i upgraded to the intex 18ft x 52 in ultra frame. So i made my hole bigger leveled it out and got her going. Its running on the intex sand 2400 gph sand filter and 15000 gallon salt water generator atm. However, my hayward skimmer is on the way. When it gets here ill put my waterway 1hp with 100lb sand filter on it and hard plum everything. Question should i leave the standard skimmer port w/o floating skimmer and the hayward skimmer so i have two inlets? I plan on adding a fountain as well. Ill post pictures soon.
    Water numbers
    FC 4
    Ph 7.6
    TA 85
    CYA 35 (still have the sock hanging trying to get the 4lbs of cya dissolved) Goal is 65-70
    Salt 3200 ppm
    BBB user since 2009
    Thanks
    Germando
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Re: Got my new pool up and opened
    I would. The Hayward will skim off the surface and the other one will pick up particles suspended below in the water.
    I would probably put a plunger valve on the old port so that you can get full suction at the Hayward if you decide to use the vacuum adapter.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2014
    15,221
    Based on the CYA chart and current reading of 35 (rounded up to 40), you should bump-up your FC to at least 5, never letting it go below 3. Use the Chlorine/CYA chart (link below) to validate your new FC level as your CYA begins to increase.
    I'm afraid I can't answer the skimmer question, so I'll leave that to another TFP'er. Congrats on the new set-up!
    Also, please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later.
    Someone who knows more than me please answer. Do I need to up my FC? I am using a swg and I thought it used a lower FC level?
    G
    Jun 2014
    15,221
    Yes, as noted above your FC should be slightly higher (5). As you use your pool and adjust your levels, you'll eventually get that SWG adjusted to where it generates the FC at the rate you need. At any time though (i.e. during SLAM) if you need to add a little liquid bleach in to immediately increase your FC, it's okay to do so.
    The SWG in itself does not mean you use less FC (chlorine), it's just making the FC for your pool. The FC level for your pool will always depend on your current CYA reading.
    According to the link in your signature it shows a target FC of 5 for a cya of 70. Mine is currently about 40. So until I get all my cya powder dissolved 4 should be fine.
    G
    Jun 2014
    15,221
    That is correct - 5 for a SWG. I didn't see that in your narrative above. For future reference. it would be helpful if you added your pool info to your signature as follows:
    Add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later.
    Hope it all works out for you.
