Thread: Slides
    Aug 2014
    East Northport, NY
    155
    Slides
    Hi.
    I am contemplating installing a slide and in terms of the water source for it, do you typically tie it in from the plumbing near the pump or do you do it fresh water from an outdoor hose spicket? I'm thinking the former but wondering what most people do. Thanks!
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    jbriggs1219's Avatar
    Apr 2015
    Brunswick/Ohio
    77
    Re: Slides
    Definitely from the pump...otherwise constantly adding cold water and messing with pool chemistry
    13,500 gallon AG
    Cartridge Filter
    Raypak Natural Gas Heater
    Aug 2014
    East Northport, NY
    155
    Re: Slides
    Quote Originally Posted by jbriggs1219 View Post
    Sent from my HTC6525LVW using Tapatalk
    Thanks. Do companies install them or is it DYI?
    TF-100 Test Kit
    Aquabot Bravo
    Re: Slides
    Quote Originally Posted by Amanda14 View Post
    I agree about connecting the slide water source to the pump. We were able to connect ours to the 'water feature' plumbing, which makes it very convenient to turn on only when needed. We were able to do the install mostly ourselves (we had our stone mason build a platform for the rear / steps portion of the slide). However, if I needed to install plumbing into an existing pool deck, I'd be inclined to contact a pool builder that does pool renovations / upgrades.
    Aug 2014
    East Northport, NY
    155
    Re: Slides
    Yep I need a pro to do it. I appreciate it! I hadn't thought about a separate pump for it however.
    TF-100 Test Kit
    Aquabot Bravo
