Thread: Pool Math question
    Nov 2014
    Palm Desert, CA
    99
    Pool Math question
    My numbers for today are:
    PH - 7.8
    TA - 80
    FC - 4.5
    CC - 0.5
    CYA - 60
    CH - 450
    Salt - 3000
    temp - 92
    CSI - 0.4
    I've been using the Taylor booklet and CSI Watergram that came with my K-2006 kit to figure my chemicals but today used the pool math. Am I correct in thinking that the CSI number Pool Math is giving me under the "Now" column is what it has calculated from my chemical numbers? It is giving me a 0.24 while my Watergram is giving me 0.4. Which is correct?
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Pool Math question
    Probably both are right. Watergram gives the The Langelier Saturation Index. CSI and LSI are two different things.
    Langelier and Calcite Saturation Indices (LSI and CSI))
