Thread: Please Help! Still Can't Find Leak!
    May 2015
    Cape Coral, Florida
    43
    I'm trying to help my parents find the leak in their pool and I think I've tried everything. They lose several inches every day. Before I call a professional, I want to make sure there is nothing else that I can try. They have a 22 year old gunite pool with the original Diamond Brite finish. I've noticed the Diamond Brite is starting flake off in certain areas but I don't see any obvious cracks or a source of a leak.
    I tried the food coloring/dye test. I checked all of the returns, skimmer, main drain, vacuum line, light, and even the hand rails. I didn't see any dye get sucked into any of the above. Then I capped all of the returns but the pools still lost water. My father says the pool loses more water when the pump is off but I wouldn't take his word for it.
    Is there anything else that I can try?
    12,000 Gallon IGP 4.0-6.0 Deep, Pebble Tec, Heliocol Solar Heating, Solar Touch Controller, Pentair IntelliFlo VS Pump, Hayward C2000 Cartridge Filter, (3) Hayward LEDs, and AutoPilot 42,000 SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Please Help! Still Can't Find Leak!
    Can you access the plumbing inside the main drain and plug that?
    If not, how about laying a heavy vinyl floor mat or something over the main drain and weigh it down with a bucket full of rocks?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    if you do not fill where does it stop going down/losing water? does it ever stop? it will stop going down at the level where the hole is...
