Thread: Should I SLAM?
    Apr 2015
    Katy, TX
    65
    Should I SLAM?
    Hello,
    I am a new pool owner and I'm using the Taylor 2006-K test. All my numbers are good except Cl. Based on my current CYA level of 40ppm, I'm supposed to have FC level of 5ppm. I'm currently at 3ppm.
    I believe my pool is clear based on the tests I've read on this forum:
    1. I can see the screws attached to my main drain.
    2. I can see whether a quarter on the floor of my pool is heads or tails.
    Today, I noticed a greenish color on the walls of my pool at the shallow end. I brushed the walls and I can see a "dust of green" fall off the wall. I think it's algae. I'm not sure.
    So my question is: Do I continue to add liquid chlorine to get to 5ppm or should I just SLAM?
    Thank you!
    24K gallon, IG, plaster, Pentair Clean and Clear Plus Filter, Pentair Heater, Pentair Intelliflo pump, Built in March 2015, Taylor K-2006, Spa included
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Should I SLAM?
    Any chance it's just pollen?
    Simplest thing is to run FC up to 10ish - it doesn't have to be exact - and let the pump run awhile, maybe even brush one lap around the pool to really get things mixed. Test FC after the sun goes down and no one else will be in the pool. Set the alarm clock and get out there and test the water again before the sun hits it tomorrow morning. Less than 1 FC loss, you're okay. Over 1 FC loss, you need to SLAM and you're already halfway to shock level AND you got a whole night's head start.
    Apr 2015
    Katy, TX
    65
    Re: Should I SLAM?
    Can you remind me how to tell between pollen and algae
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Should I SLAM?
    Quote Originally Posted by Brian T View Post
    Easiest way is to look around you. If the patio furniture and the windowsills and any parked cars nearby are covered with it, so's your pool.
    Or read all the old threads about it: Search
