Thread: Spectralight uv system.....good, bad, etc
    May 2015
    Union, NJ
    128
    Does any has the spectra ultraviolet system? I considering getting one, but would like to know if it works and what have users experience been with the UV system.
    20,000 Gallons, 33.9 x 19.9 free form inground plaster pool 7 feet deep with Spillover Spa, Salt Generator (Fusion Soft),Heat Pump, Single Speed 2 HP Pump, D.E. Filter. Zodicac PDA, IQ900RS Controller.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Spectralight uv system.....good, bad, etc
    It is our general opinion here that UV systems do not provide much if any benefit to typical outdoor residential pools as most residential pools get more than enough UV exposure from sunlight to break down CC compounds, and added UV from these systems has no additional benefit in properly chlorinated pools, in fact they do have the side effect of increasing chlorine usage in a properly balanced pool. This is not to say that UV systems do not have a place, they can be a great benefit in situations where supplemental oxidation is needed, such as commercial therapy pools, indoor pools, stand alone spa's, etc.
