Results 1 to 8 of 8
Thread: How often do you add your bleach?
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Some of you may have read in one of my other posts that we bought a home with a pool and although it looks great the numbers are high from years of tab chlorine. I will be doing a partial water change to get my CYA down from 100 and will be a BBB user. I have not added any chlorine since we moved in because FC is still high at 16. I am however curious though in the meantime on your cycle of adding bleach to your pool. Are you adding a little every day or every other day or so?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Re: How often do you add your bleach?
    Most people add bleach once a day, best done in the early evening though that is not crucial. When your CYA level is very high you can usually get away with adding bleach less often, sometimes much less often depending on your CYA level.
    Apr 2008
    Central Texas
    326
    During the summer I was adding 3 quarts each day. Now that the water has cooled down and the sun is shining on it less each day it only needs 3 quarts about once every 5 days or so. I suppose I could add a quart every couple of days, but I don't think about the pool much this time of year...
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    My normal routine is to test daily, keep my FC in the proper range according to the CYA chart. Most of the time I would add bleach every other day, setting it at the high end of the range and adding more bleach when the FC tested at the low end. I never let it get below minimum. Works for me. Once your water is balanced, and you have a basic pool like me (no water features like spa, fall, etc.) it really is 5 minutes a day. That's what is so great about BBB.
    revstriker's Avatar
    Apr 2008
    Texas
    117
    In season, I test daily and add bleach daily. I need MA every couple of days.
    In the winter, I test weekly and add what's needed weekly. Even after 7 days, there really isn't much of a change.
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
    Jun 2008
    Marana, AZ
    347
    I usually add some every day in the summer. I never had any problems if I had to skip a day though. I just would use my little OTO tester to tell me how much to add. After awhile I knew about how much my pool consumed in a day, so if I just had a few seconds, well, dump in the 2 cups of bleach and call it good. That's another cool thing about BBB. You get to know your pool! (But don't add chlorine very often without testing, and don't do it until you have a good idea how much to add. Otherwise, you will underchlorinate and get an algae bloom or overchlorinate.)
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    In the summer, I test daily and add daily, unless I add a little more than necessary one day so I can skip a day. This is our first winter with our pool (we opted to leave it open adn running) and I'm finding that it's hardly using any chlorine at all. In fact, I've only bought a couple of 174 oz Wally World bottles since the cold weather moved in. But because of the high winds, I do watch the ph and add MA as necessary. I check my skimmer every couple of days to pull the neighbors' leaves out of it! So far, it's pretty much been a maintenance-free pool this winter.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    In the summer, I test before i leave for work about 8:30 am...If needed I add before the kids swim, I always test in the evening after 6 pm. This is when i add the chlorine Most of the time...If I add in the evening it is usually 2-4 cups and that keeps me in the appropriate range...i try to stay at 3 - 5 PPm, and sometimes more. My pool sits in direct sunlight for at least 9-10 hours per day. This means that I do lose more chlorine due to burn off. My CYA usually sits at 40 to 60 ppm. Still at this rate I have to add at least 2 cups of Chlorine every day...I have kids who have friends...at any given day there are atleast 4-6 people in our pool through out the day...God knows i am in every night after work and all weekend. I will say this. The BBB method is really easy to do, it may seem like it is a lot of work, but it mostly is just testing and making sure you stay in balance...To be honest...I make points with my wife because she thinks I am working really hard to keep the pool fresh and clean for her to relax in all day...She doesn't know that it really is easy...the hardest thing I do really is throw the auto vac into the pool in the evening. WHOO HOO! More time to enjoy the pool...less time in the pool store. Pool Mom...don't tell!!! I don't want my secret out!!!
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
