Thread: Water still a little cloudy New Numbers
    Jun 2015
    Chesapeake, VA
    8
    Ok I haven't received my kit yet so i am still relying on Leslie's for my testing.
    FAC = 0
    TAC= 0
    CH = 240
    CYA = 80
    TA = 110
    pH = 7.4
    Copper = 0
    Iron = 0
    TDS = 1200
    Pho = 200
    Pool wanted me to buy phos free for the phosphates, but i declined. If i can control the algae then phosphates will not matter, also said he wouldn't put Borax in the pool, doesn't no how safe it is. I giggled.
    18ft round, 9500 Gal, Vinyl Liner.1.75 HP pump, Sand Filter.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: Water still a little cloudy New Numbers
    Your in very dangerous waters right now! You need to get some chlorine in that pool, and keep it in there. If your CYA is really 80, then you should always have a FC of at least 6.
    Also unless you have a SWG, I would start accepting he fact that you will need to do a large drain and fill to get your CYA down. Wait until your kit comes first though so you can do a real CYA test.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    I would wait on draining to correct CYA until you have your own test kit. Pool stores are notoriously inaccurate on that test. You do want to get some chlorine in the pool but without knowing your true CYA I'd target a minimum of 3-4 until you get good test results.
    With cloudy water, I suspect you will need to SLAM your pool when your test kit arrives.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2015
    Chesapeake, VA
    8
    I added 2 lbs of shock, not bleach yet as i have already paid fir this stuff might add well use it. I don't give much credence to the CYA test from the poo guys. They tested it last Friday and said it was 0 and i needed to add stabilizer. So i added what they recommended now it is 80. By the chart on the bucket it should have only raised it 30 ppm
