Thread: Adding bleach every other day
    I need to add about 160 ounces of bleach to my pool every other day. Every other reading for my pool water is perfect. Is this normal or is there something else going on?
    My CYA is 45.
    Eddie
    30 foot round pool. 4 feet deep.
    21,200 gallons
    AG
    Sand filter
    Taylor FAS-DPD Testing kit
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Adding bleach every other day
    I would say that's about right. 160 oz of 8.25% will give you 5ppm so your burning 2.5ppm a day. If it's say 12.5% then that might be on the high side. With 45 cya you should not be dropping below 4. I take it you target 9 every two days. Also as the summer heats up, your natural demand may go up.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Jun 2014
    14,970
    Hello Eddie. Initially it seems as though that much bleach may be explainable. Several factors could explain that kind of usage. But just to confirm ... how did you test the CYA? Your own kit? Which one? Also, the staff here would be glad to review all of your results if you care to share them with us just to make sure we don't see something you may not have considered. Best of luck.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    for a pool of yours size, i say thats about right.
    Divin Dave,
