Thread: Black scum ring in skimmer
    Mid-West Infidel's Avatar
    Jun 2015
    South KC, Missouri
    44
    First of all a brief history-
    We've had the pool for about 8 years now. Seems like every year I have some kind of algae issue. I think part of my problem is all the trees around me... I only get full sun from about 10am to 3:30 pm. I found TFP late last year and after some thought, decided to try the liquid chlorine method this year. Actually, want to use up my remaining 3 in 1 tabs, while monitoring CYA. I figure when it starts creeping up, I'll make the switch.
    I just installed a new liner, filled pool and water is nearly balanced (see below). Like last year, I am already starting to see a black scum ring developing in the skimmer box. No one has been in the water yet, so I don't think lotions, etc. are a concern.
    I installed new sand in my filter last year, by the way.
    Can anyone tell me why this is happening and how to correct it?
    TA-60
    CH-110
    pH-7.4
    CYA-<30
    FC-12.5 We've had a bit of rain so I did add some liquid bleach (obviously too much)...
    CC-0.5
    BD-1
    You can start to see it in this pic:
    Attachment 38400
    24' round, above-ground Doughboy, Mistique 52" side-wall pool w/ bowl shaped bottom. (approx 15,200 gallons). Installed in 2007.
    #200 Sand Dollar Filter. All new sand in 2014.
    1.5 HP Dynamo pump. New impeller and shaft seal in 2015.
    New liner installed in 2015.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,548
    Re: Black scum ring in skimmer
    I have the same thing. I just scrub it with a Magic Eraser and it is good for a while. I do not know what it is but I too have trees around.
    Kim
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Here you go. It is also characterized by a ring in the skimmer as you described.
    http://www.cgtpoolliners.com/tb-7
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Jun 2015
    South KC, Missouri
    44
    Quote Originally Posted by Scuba_Steve View Post
    Thanks for the link Scuba_Steve. The stuff ends up like tar, that's for sure!
    Casey's Avatar
    SW PA
    10,448
    You can buy a scum ball n throw it in the skimmer box. It'll absorb that and keep it from adhering to the skimmer.
    Jun 2015
    South KC, Missouri
    44
    Quote Originally Posted by Casey View Post
    Never heard of the scum ball, but I Googled.... Sounds like a plan.
    Thanks!!!
