Thread: TF-100 OTO test
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    TF-100 OTO test
    OK my FC is 16 so that renders my OTO test useless or does it. I have read that you can add 10% pool water to 90% distilled water test and read then multiply the result by 10. Will that work with this OTO test for high TC values on a daily basis or don’t bother?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    30,426
    Re: TF-100 OTO test
    No, it won't work. The accuracy gets diluted by virtually the same amount so it renders the test almost useless. You'll need to test with your FAS/DPD test for now and then use the OTO this coming Spring (or when you get your CYA down).
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Re: TF-100 OTO test
    OK thanks for clearing that up
    Polaris 280 robot
    Pool Calc user
