Results 1 to 13 of 13
Thread: New Steps
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    New Steps
    Hi everyone! I just ordered my very first set of steps for my pool. I have always just used the ladder mounted to the deck, but knee problems are making it more difficult. I ordered the Confer Curve base set. They seemed to have very good reviews. My question would be: Do any of you have these and how do you like them? It says to fill with 50 lbs of sand. Will this make them too heavy to get in and out of the pool or should me and my 20 yr old daughter be able to handle it? Any ideas or suggestions will be appreciated. I always get the best advice from everyone here!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Orlando, FL
    690
    Re: New Steps
    I have the Confer ladder with the gate and I have the set with the curved steps that you can put a light in. I put both sets in, multiple times by myself, so, you and your daughter will be fine. Both of you outside the pool and you lift them and balance them on the top rail. Then, one of you can get in and guide them down into the pool. They tend to float so the person in the pool will have to do a little work to get them to stay down. Whatever you plan to weigh them down with should be in the pool so that it can be put into place immediately. I used plastic coated weights and a brick covered in plastic. Some people use bleach bottles filled with pebbles, sand, etc. Regardless, the curved steps are going to require some kind of weight to keep them from floating.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: New Steps
    Thanks. I've been doing some research and there have been all kinds of great ideas. I guess I'll figure it out when they get here and I put them together.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,612
    Re: New Steps
    I do not like the "wrapped" in plastic because there are just too many curves, bends, overlaps for yucky stuff to hide in.
    The plastic bottles filled with cement work great. Just attach them using zip ties you can cut when you want to take the steps out.
    Some people make "weights using PVC and cement. Again attach using zip ties.
    The bad of sand is not a good idea. After a while the bag will deteriorate and you have a mess on your hands.
    Get a turkey baster so you can "shoot" some bleach inside them every other day or so to keep them clean.
    Kim
    Exton, PA
    249
    Re: New Steps
    I have wedding cake steps and use plastic covered weights from a weight lifting set. They are leaking of bit of Crete or whatever is used inside them, but it's been a few years and I haven't had any issues. I was using more, but this year in going with 75 pounds.
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    Orlando, FL
    690
    Re: New Steps
    I have not had any issues with algae in the plastic but, it was not intended as a permanent solution. It works and I have left it alone because, well, I am lazy. Lol
    Jul 2012
    Tallahassee, FL
    30,612
    Re: New Steps
    LOL but you have been here at TFP how long???????????? You know what to do to keep problems from happening!
    I am sure the OP will not have any problems as they have been here for a while also!
    Kim
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: New Steps
    Yep, I've been around since my conversion from Baquacil to chlorine. And I've learned so much along the way thanks to the great people on this forum. I was wondering about the steps because some people said they floated and some people said they didn't, but thanks to this crew, I can channel my inner MacGuyver (as long as I don't use bubblegum and duct tape)
    Orlando, FL
    690
    Re: New Steps
    Quote Originally Posted by kimkats View Post
    Kim
    I have been around for a few years and I finally get to enjoy my pool. I am very glad I stuck around and read everything until it all finally made sense.
    Casey's Avatar
    SW PA
    10,457
    Re: New Steps
    Hey Pepsiholic, Welcome back for another trouble free season.
    I filled my steps with sand and regretted it. It still floated and it took 3 of us to take them out of the pool at the end of the season n those steps hit the ground and my steps fell apart with such force! The next year, my gf and I drilled holes in the bottom, ran a garden hose in one hole n,forced the sand out the other. I'm so glad we did it! Now, I hold my steps down with bleach bottles n bungie cords.
    I have the green cords holding my jugs in place. The blue cords on the top handle bar at the base of the steps clips on the top rail of the pool to keep them in place. I absolutely love this set up because Its so easy to move them n clean under them.
    Mar 2014
    south central PA
    112
    Re: New Steps
    We just put these same steps in. We filled with sand (and regret, as Casey said) and those suckers are heavy with the sand in them. And still float. We now have a bunch of bleach bottles filled with sand to keep them weighted down as well. We were just discussing how to best attach the bottles, and I'm going to try Casey's method above (thanks! Going to get the bungies this morning!). So, if you don't fill the steps with sand you should be fine getting them out. Prep your bottles/weights in advance and you will be happy!
    (Stairs are fantastic by the way, we love them. Glad we got them, and they are great for the kids to sit on as well).
    28 ft round ABG with ~6ft deep end, approx. 20,000 gal, 2 spd 2 HP pump, sand filter
    May 2012
    Montville NJ
    545
    Re: New Steps
    I have different steps - but as far as weights are concerned. I filled my weigh containers with pea gravel. If they break open, it is a lot easer to clean up than sand. Also the space between the individual grains lets me fill the container with a strong beach/water mix, which helps eliminate anything from growing inside.
    I guess filling them with cement would do the same thing, but pea gravel was a lot easier.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Casey's Avatar
    SW PA
    10,457
    Re: New Steps
    I bought the bungies with plastic ends at Wal-Mart pigeon. I have to replace them every year.
