Thread: Yikes,...sanity check these numbers....
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    My pool is fine. Friend just pulled the cover off of their above ground 12K gallon pool yesterday and tossed in a couple pounds of granular shock. I said to hold on till I can get her a good reading so I took my trusty TFT100 kit and got the following...
    FC = 2
    CC = 7 (yikes)
    TC = 9
    CH = 275
    TA = 80
    CYA = 25
    Ph = 7.4
    Based on that... I would assume the chlorine/shock is the most important thing to get right now. Pool match shows 178 oz of 8.25% to get to the shock level of 12. Sound like a good start? That is about 1.5 gallons. That and 24 oz of stabilizer, but I wasn't sure of that was prudent at first opening in case she needs to do some backwashing due to vacuuming. Pool is a tad dirty. Not horrific, but needs soem cleaning. Hayward DE filter on it.
    28K gallon, raised beam, plaster/ceramic color quartz with attached spa. TF-100 test kit
    Hayward 1.5HP super pump, DE4800 DE filter, Hayward inline chlorinator w/3" tabs (off)
    Pool: 2 floor drains, 2 skimmers, 3 floor returns, 2 wall returns, 3.5' deep > 8' deep
    Spa: 2 floor drains, 4 jet returns
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Re: Yikes,...sanity check these numbers....
    SLAM it using a current CYA level of 30 without adding any.
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Great, thanks!!
