Thread: Setting up Hayward Super Pump vs Controls
    I just installed a new Hayward Super Pump VS and I need help in setting the controls up. I find it difficult with the user manual and Youtube videos.
    I have a Intermeter 24 hour dial meter.
    My pool is 20x40 with a Hayward sand filter.
    How many hours a day should I run the pump? At what speeds?
    What do I do after I turn the power on. I know that there is priming cycle of four minutes.
    I would like to go back to factory defaults and have someone walk we through the process.
    I will be every thankful
    Bill
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Setting up Hayward Super Pump vs Controls
    The VS has it's own built in controller and should have power 24/7 and not via that Intermatic. I'm not sure how long it can keep it's clock and other settings, but even an Aqualogic controller can only go about seven hours, so you will lose your settings I'd think when the Intermatic cuts power.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    38,284
    Quote Originally Posted by NeedMoreSun View Post
    This may not be correct. Some of the smaller VS pumps like this only have a countdown timer to switch speeds and still need to be controlled by an external timer.
    Take a look at the Determine Pump Run Time article in Pool School.
    Mar 2015
    380
    Thanks to you guys you can catch those slips
    Scott
    Thanks everyone for your comments
    Jan 2012
    340
    Newest revision of Super Pump VS has built time clock and needs uninterrupted power. Basic breakdown of programming:
    -Set time of day
    -Set on time and duration of speed one
    -Set duration of speed two to run after speed one
    -Set duration of speed three to run after speed two
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
