I needs some major help. I can see the bottom of the shallow end if no one has been swimming for a day or two, I have never been able to see the bottom of the deep end. We had some CYA issues last year and dumped half of the pool water then refilled it from our well. Below are my current readings from this morning.
FC = 0
TC = 0.5
CYA = 55
PH = 7.2
TA = 150
CH = 0
Saturation Index = -1.5
I tried shocking the pool (we only use bleach) at the end of May but the pool pump broke and it took a week to get the replacement in. I have been running my pump 24/7 since I took the cover off with the exception being the week of the broken pump and the water is still cloudy. The pool is 18 X 36, the pool store estimated it was 33,800 gallons but I wonder if our gallon size is off and if that is throwing things off. The deep end is 9 feet deep and the pool slants deep pretty quickly. There are two drains, one at the bottom of the deep end and a skimmer drain. I have run the kreepy crawly off and on for weeks. I still see what looks like sediment collecting on the stairs in the shallow end. We are using a cartridge filter. Any suggestions on what I should try next.
FC = 0
TC = 0.5
CYA = 55
PH = 7.2
TA = 150
CH = 0
