Results 1 to 7 of 7
Thread: AGP High alkalinity, ph and hardness, help please
    Jun 2015
    wpb
    6
    Question AGP High alkalinity, ph and hardness, help please
    First, this forum is simply amazing. Having frequented many through the years, this is the first I have ever seen so consistently helpful to others. It is a breath of fresh air.
    Now to our problem. We have an above ground pool we are having trouble getting balanced. This is our 5th agp. It was filled a couple of weeks ago with well water, which is the same as the last 2 we have had. We have managed to remove most of the 'rust' from the pool. Yay! But according to our clorox 6 test strip and aqua chem test kit, our chlorine-total and free, is ideal, and ph high. The clorox also shows high water hardness, at least 1000 or more, which was not unexpected, ph at 8.4 or higher, and total alkalinity at 240 or higher. Stabilizer shows as ok. What do we need to add, please? i am confused regarding what I read, as it seems treating alkalinity can raise the ph, etc. I know my understanding is just screwed up, what can I say? Ha! Any help would be much appreciated as to what products/ chemicals to use. We used super shock and super water clarifier to help remove the rust.
    And thank you in advance.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: AGP High alkalinity, ph and hardness, help please
    Pool School - Lower Total Alkalinity
    There ya' go! Welcome.
    Jun 2015
    wpb
    6
    AGP Intex ultra-frame 18' 48", krystal clear 1500 gpm with cartridge filter
    don't know if it is because I added my signature after making the thread that itis not showing to me in the above post, so here is the pool we have.
    Thank you, woodyp. So muriatic acid will lower both? I guess my confusion comes in when it states ph rising. I know, I am known for overthinking sometimes. Is that what I am doing here? Also, if I understand correctly, lowering the alkalinity will also lower hardness, correct?
    Apr 2010
    East Texas
    9,581
    MA will lower both over........TIME......as a process. Constantly letting PH rise on it's own or by aeration, then knocking it back down helps to lower TA. No effect on CH. You need to keep your PH is low 7 range to combat calcium scaling though.
    Jun 2015
    wpb
    6
    Thank you. The pool calculator says to add 107 oz. so I just got it and will add it now.
    Jun 2015
    wpb
    6
    Quick update. Everything looks good now except stabilizer is now too low. Will check again the morning and see what it reads. Thanks again for the help.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    Please update your location and pool info as shown here,
    Pool School - Read This BEFORE You Post
