Results 1 to 9 of 9
Thread: Liguid plumber?
    Liguid plumber?
    I think I could have debris stuck in one of my skimmer pipes. Is it ok to pour liquid plumber into the skimmer to see if it will dissolve what may be
    clogging the pipe.
    I have one skimmer. When I shut off the main drain the pump will sucks all the water out of the skimmer line then it fills back up and it sucks it all out again. Over and over. Thats the best way I can describe it.
    14,500 gal pool
    Inground
    Intellichlor Salt Generator
    Water Fall
    Jun 2014
    15,103
    Re: Liguid plumber?
    Ooooh, using LP doesn't sound like an ideal thing to use in my opinion. Might open-up a slew of chemical changes. Many others have had pugged pipes and resolved them manually with a plumbers snake or perhaps air pressure. Sometimes water pushing backwards. I would wait for another reply or two from the TFP veterans to confirm though. I don't want to steer your wrong, just be cautious.
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: Liguid plumber?
    Noooooooooooo!!
    LP is way too caustic for your pools equipment. You can easily damage your equipment with it. If the line is truly clogged you need to blow it out using a hose bladder or, very carefully with compressed air.
    Matt
    Feb 2014
    Upstate, NY
    390
    Re: Liguid plumber?
    Definitely NG!!!!
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Liguid plumber?
    Ouch! I'd suspect even diluted that stuff may burn!!! Well, at least they don't use lye in that stuff anymore
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Re: Liguid plumber?
    Thanks guys. I'll go another route
    14,500 gal pool
    Inground
    Water Fall
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Liguid plumber?
    Quote Originally Posted by Miscanthus View Post
    I think your pipe is fine. What you are describing sounds more like a sticking weir, low water level or a pump that just moves more water than the skimmer alone can supply.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Liguid plumber?
    Surging like you describe is most usually a stuck weir flapper or low water. The pump catches prime, it sucks the skimmer dry, loses prime, skimmer refills. Repeat.
    May 2015
    13,201
    Re: Liguid plumber?
    Quote Originally Posted by NeedMoreSun View Post
    Actually lye is sodium hydroxide in solid form. Many formulations of LP, Draino, etc, use different concentrations of sodium hydroxide in solution.
    Sodium hydroxide is extremely caustic even at low concentrations. Glue joints and certain kinds of plastics can be easily damaged by a slug of high pH water sitting in one area for too long.
    Matt
