Thread: Vacuum with Sand Filter
    Jun 2013
    MA
    104
    I just purchased the Krystal Clear Sand Filter Pump Model SF70110 for my 18x48 ultra frame intex pool. I also bought a new vacuum head but I'm having a problem with the debris getting clogged in the intake connector of the pool. Their is no way of taking the strainer off. I had to use an adapter that screw on the strainer in order to use the hose. I vacuum the pool and when I take the connector and hose off all the debris goes back into the pool. Very frustrating. Anyone have any advice on what I could do to prevent this?pool adapter.jpg
    18x48 ultra frame AG Intex pool 6423 gallons
    Test kit - TF-100
    30,424
    Re: Vacuum with Sand Filter
    I can see the problem (nice pic...Thanks!) but have no idea of the solution. Intex is a unique brand that seems to have a lot of unique problems.....not easily fixed.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,541
    Yeah, I remember those days. I used to keep my net handy, but some of the stuff always got loose and back into the pool.
    The only real solution I know of is to install a thru-the-wall skimmer like my Hayward Dyna-skim. It comes with an adapter played to which you can connect a vacuum. And it does a much better job of keeping the pool clean to begin with.
    Don't be afraid to cut your liner -- it's simple to install. And you will never regret it.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
