Thread: Picked wrong year
    Jun 2015
    Bessemer,Mi
    42
    Picked wrong year
    I picked the wrong year to put up a pool lol
    strong El Niņo causing well below average temps for July and august
    guess I'm gonna need to build a heater or heat pool somehow.
    My luck. Lol. Ohwell hopefully it makes it through the winter
    cuz I just got done adding an addition on my deck to go around part of the pool
    16x48 intex ultraframe. 5300 +or-
    cheapo intex filter for now.
    Taylor k2006.
    Working on the partial wrap around deck
    NEED to add a skimmer!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Picked wrong year
    Right! Been having trouble keeping water temps up way down here in tx. Can't imagine how much colder it is waaayyy up north. Brrrr
    Jun 2015
    Bessemer,Mi
    42
    All week this week the highest is gonna be 68. Unreal
    Taylor k2006.
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    JEALOUS!
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    JoyfulNoise's Avatar
    May 2015
    13,231
    Yeah, eve here in Tucson the weather is unusually cool. We should be hitting 100F every day in June. May and June are the hot & dry months before the monsoon rains hit in mid-July and the humidity kicks up (and, YES, it does rain in the desert!!!). HOWEVEVR, we had a crazy weird May and it wasn't until the last week in May that the temps broke over 90F. Even in mid-June now we're getting days only in the mid-90's and the overnight temps still drop down into the 70's. I only have a gas heater for the spa that I can use on the pool but it would consume too much NG to heat up my pool even 4 deg F. So we basically spent all of April and most of May looking at an empty (of people) pool.
    Friends of ours have solar heaters....I'm seriously considering dropping the Benjamin's to get one....
    Matt
    May 2015
    Chickasha, OK
    184
    A neighbor of mine has a unique way to heat his pool...
    He has probably 200 feet of garden hose laid neatly in a zig-zag pattern on the roof of his pool house. Pumps pool water through hose, then back into pool. He says it works great. I'm sure he has it plumbed into his pool pump somehow, but a person could rig up the same setup with a strong sump pump dropped in the deep end, with the hose replacing the water in the shallow end.
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
