Thread: First post with a few questions about my AGP and SWG set up.
    Jun 2015
    Annapolis/MD
    3
    I spent the last week leveling the pool site. We set the pool up yesterday and have water getting delivered today. Once the water gets here I plan to test it and post the readings. What should my plan of action be if my goal is to get my family in the pool quickly (everyone is ready and excited)? I've seen a few people mention start up the pool with normal chemicals get it dialed in then start the salt process..is that right? I have Salt, I need to buy CYA...what other additives will I need. Thanks in advance.
    Intex 15 x 42 Metal Frame Pool @ 3800G | 28647EG Intex 2800 GPH Sand Filter Pump | Intex Krystal Clear SWG CG-28669 with E.C.O. | K-2006 TEST KIT
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: First post with a few questions about my AGP and SWG set up.
    Welcome to TFP!
    Have bleach on hand to manually chlorinate the pool for the first few days. The salt is going to fake time to melt and you won't be able to crank up,the SWG as soon as the water is in.
    So, start the pump and get water moving. Add bleach to get to 1ppm.
    Measure CYA to get to 40, place in a sock and hang in front of a return. You want to take CYA up in steps so you don't overshoot.
    Adjust pH to the mid 7s
    Test TA & CH but do not adjust for now.
    Day two assume the CYA has reached 40 and chlorinate based on that.
    Continue bleach chlorination until you have the salt in the pool and the SWG is working.
    Support the site
    Jun 2015
    Annapolis/MD
    3
    Tim thanks for your help. When is it "safe to let them family enjoy the pool? Day1 or do I need to wait a few days?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    It is safe to swim when your pool is balanced and your FC is in line with your CYA.
    Add the salt any time you like-doesn't effect other readings. People do it all the time even without a SWG for the "feel".
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP! Congrats on the new pool!
    You can swim on day one as soon as it is full, the pump is on and the PH is between 7.2 and 7.8.
    After day one it is safe to swim when:
    PH is 7.2-7.8
    Chlorine is above minimum level for your CYA
    Chlorine is below shock level for your CYA
    Water is clear
    Here is the Chlorine CYA Chart
    Here are some great article from Pool School to get you started with water maintenance
    Pool School - Water Balance for SWGs
    Pool School - PoolMath
    Jun 2015
    Annapolis/MD
    3
    Thanks for the advice everyone. Water is here I'm about to go test it.
