Hi all,
Out pool is new and we still haven't hooked up the salt cell so we are manually chlorinating for another week or two. We are swimming and I think the water is ok but this morning I tested using the TF-100 and below are the results:
pH: 7.8
FC: 4 ppm
CC: 0 ppm
TC: 4 ppm
TA: 50
CYA: not sure...I followed the directions but I could continue to see the black dot even after all of the solution was poured into the cyclinder
Looks like I have no Combined Chloramines - should I be concerned about that? Also, TA is low, according to the directions it should be around 100-120. And what about the CYA?
I'm new to this, so I'm not sure what the right adjustments are to make.
thank you
pH: 7.8
FC: 4 ppm
CC: 0 ppm
TC: 4 ppm
TA: 50
thank you
