Results 1 to 8 of 8
Thread: New Test Kit TF-100 - 1st test results
    May 2015
    Jacksonville, Florida
    15
    Smile New Test Kit TF-100 - 1st test results
    Hi all,
    Out pool is new and we still haven't hooked up the salt cell so we are manually chlorinating for another week or two. We are swimming and I think the water is ok but this morning I tested using the TF-100 and below are the results:
    pH: 7.8
    FC: 4 ppm
    CC: 0 ppm
    TC: 4 ppm
    TA: 50
    CYA: not sure...I followed the directions but I could continue to see the black dot even after all of the solution was poured into the cyclinder
    Looks like I have no Combined Chloramines - should I be concerned about that? Also, TA is low, according to the directions it should be around 100-120. And what about the CYA?
    I'm new to this, so I'm not sure what the right adjustments are to make.
    thank you
    My Pool: 19,000 gallon In-Ground Screen Enclosed, Finish: NPT StoneScapes Mini Pebble Tropics Blue, Controller/Heater: Hayward ProLogic P4 w/T-15 SWG
    Pool Filter: Hayward Cartridge Star Clear Plus, Pool Pump: Hayward VSP SP3400VSP, No Spa, TF-100 Test Kit.
    Pool Installation: Plaster Complete 5/23/2015
    Jun 2014
    15,298
    Re: New Test Kit TF-100 - 1st test results
    No CC is good! You always want less than .5. Being a new pool though, make sure you follow your builder's recommendations for plaster and check out this link: Pool School - Start-up New Plaster
    Once you know for sure you can adjust the levels and add more stabilizer, just follow the recommendation level and Chlorine/CYA chart links below in my sig.
    If you continue to have problems reading CYA, we can help.
    By the way - Congrats on the test kit! Best thing you could do for your pool, sanity, and pocketbook.
    May 2015
    Kentucky
    19
    Welcome to the group Marshall! Im new at this also but these guys fixed me right up with their suggestions to get everything back on track for me. I started with a black swamp, haha. Just listen to their suggestions closely and start educating yourself thru the links on Texas Splashs signature. Looks like to me your numbers arent so bad for a first reading though. They'll have you fixed up in no time!
    15,000 gal - AG - Vinyl Beaded Liner
    Pentair Meteor 22" Sand Filter
    Pentair Dynamo 1.5HP Pump
    Installed Summer 2014
    TF-100 Test Kit, City Water
    May 2015
    15
    Thanks! On my first post it was recommended that I get the TF-100 so I started there...
    The builder and the manufacturer say that we're good to swim as soon as we can balance chemicals. I'll take a look at the CYA chart now. thanks!
    Jun 2014
    15,298
    This link/thread has some more info on how to do the CYA test. Maybe it will help you.
    CYA test
    30,432
    In a nutshell, you have zero CYA and need to get some in your pool.
    Use PoolMath and calculate enough to get your pool to 40 ppm.
    Once you put it in, there will be no need to test for it for a week or so. Just calc the dose carefully and correctly so you will know it's in there.
    What does your water look like?
    May 2015
    15
    Perfect, thanks duraleigh. Water is clear and looks great. temp is 82 degrees!
    I just want to be sure all of the levels are safe for the kids. I'm headed to the store shortly to take care of the CYA issue. Thanks for the help.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    If you have not added CYA to the pool then there isn't any in there. Put 30ppm in a sock and toss it in the skimmer basket. Chlorinate to CYA of 30.
    It is important to maintain PH between 7.2 and 7.8
    It is important not to let the chlorine level drop below the minimum level for your CYA level. When chlorine drops below minimum level the pool is not properly sanitized and algae will start growing.
    It is safe to swim when:
    PH is between 7.2 & 7.8
    Chlorine is between min and shock for your CYA
    Your water is clear
    Here is some good stuff to read
    Pool School - Water Balance for SWGs
