Thread: Help with Intek above ground pool.
    Jun 2015
    st. Peters , mo
    1
    I recently purchased a home that had a 15ft or so Intek above ground pool. It wasn't covered for a while and its turned dark brown and there are tadpoles and debris in it. I'm unsure if it would be easier to drain it or try to fix it chemically or partial drain. Don't know what to do. Please help and thanks for any advice in advance.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Help with Intek above ground pool.
    Welcome to TFP!
    Often with smaller pools it is most efficient to follow this guide.
    Pool School - Guide for Seasonal/Temporary Pools
    Jun 2014
    15,059
    Welcome to TFP! Happy you joined us.
