Thread: Help with Raypak Rp2100
    Jun 2015
    Detroit
    17
    First of all thanks in advance for any advice!
    So.. Raypak rp2100 266k Heater calls for heat, and I hear the audible sparking, then Heater ignites without issue...
    Every 30 secs thereafter I can hear it sparking again, along with "spk" on the readout.
    Don't think this is normal.. Even though the heater is on and functioning!
    Please advise if this is an easy fix, as this is an older heater and I don't want to spend a great deal of money fixing it..
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Help with Raypak Rp2100
    Unless your ignitor is in bad shape, I would suspect a bad control board is what you have. $250 - $300 for a new board.
    Also, just double check your green ground wire down by the ignitor.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2015
    Detroit
    17
    Quote Originally Posted by ps0303 View Post
    Don't see green wire at all.. Just the blue wire to the ignitor. (high tension I'm guessing)
    The problem persists.. Ughhh..
    I've found some boards on eBay.. But not sure the repair is worth it..
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Here is a picture of what I am trying to describe. See the green wire that is wrapped around the pilot tube? You don't have that??
    Paul
    Jun 2015
    Detroit
    17
    Nope.. Just a blue wire
    Jun 2015
    Detroit
    17
    I'll go check again..
