Thread: SWCG - Run time vs Cell output
    Jul 2014
    Manalapan, New Jersey
    98
    So I have a smaller pool and I run my pump for 3 hours a day (My pump turns over my pool water ~ every 67 min (I think)) and my FC is about 2 (everything is good, CC is <0.5). My cell is at 50%. So the general question is, is it better to increase my run time (to 4 hours) or to increase my cell output (to 60-70%)?
    23k gal in-ground gunite w/ spa/blower, Sheer descent, Jandy AquaPure SWCG, Pentair 2HP Pump x2, Raypak P-R406A-EN-C 399k BTU gas heater, Polaris 380/Polaris PB4-60 Pump, DE filter w/ separation tank
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: SWCG - Run time vs Cell output
    Hi Friguy,
    the answer is to do which best suits you.
    If you increase our run time, it will cost you a little bit of electricy.
    If you increase your output, it will shorten the overall life span of the cell.
    So, its sort of a trade off in that respect.
    If you have a 2 speed pump, then the most logical answer would be lengthen the run time because of the extreme efficience of a 2 speed over a single speed. A couple extra hours of low speed would not cost much at all.
    Divin Dave,
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Increasing run time also shortens the cell life. It will only put out a finite amount of chlorine over its life span. So either way shortens life span.
    How clean and crystal clear is your water? Do you need the extra filter time?
    chiefwej
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    What is your CYA level? An FC of 2 is very low for a SW pool.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Jul 2014
    98
    Water is crystal clear, cya and all my other numbers were good (sorry don't have them in front of me)
    ---the main general question is, for a SWCG and chlorine levels, would you increase pump time (I guess youd do that if you want more cleaning time too) or would you increase the cell output, or does it not matter. If youre at 3hours at 50%. Are 4 hours at 50% equal to 3 hours at 67%. Both equal 2 hours of chlorine production time. Is one better than the other?
