Thread: Calcium Hardness vinyl - first time testing
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    TF100 user here for the past 2 years
    Had a recent bout w heavy thunderstorms that really bottomed out my TA - and after raising and retesting , got a wild hair and decided to check my CH for the FIRST time ever
    I have a 20k gallon vinyl with a new liner about 2 yrs old - been steady TFPC since new liner install and have been trouble free since (!)
    My CH measures 30
    Which - I understand - is very low
    Is this something that I should even give a second thought to??
    FC 7
    CYA 40
    pH 7.5
    CC ZERO
    TA adjusted to 80 from 40
    CH 30
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Calcium Hardness vinyl - first time testing
    CH is not needed for vinyl pools unless you need it for some warranty reason where some minimum level is specified without regard to type of pool (this happens with some heaters even though low CH is not bad for the heaters)
    rhaas12321's Avatar
    Jul 2012
    Sunny Southern Oregon
    41
    What if you have concrete decking surrounding the pool? Does low CH splash out deteriorate the decking?
    10k Gallon, IG Kafko Vinyl Liner (8/1/12), 200# Sand w/ 1 hp Hayward MaxFlo pump, Taylor K2006
    3 4x12 Heliocol East facing + 3 4x12 Heliocol West facing 2015
    Robert from Sunny Southern Oregon
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by rhaas12321 View Post
    No worse than rain. Rain has no calcium.
    Jun 2013
    southeast
    118
    So - consensus is no worries ?
