Results 1 to 8 of 8
Thread: Is adding around 100 ounces of bleach per day
    Jul 2014
    Evansville, IN
    72
    Seem about right? Cya is 40. 15,000 gallon pool. Just seems like a lot to me. It is usually around 90 degrees outside and the pool gets full sun all day. It is used a lot also. Thx
    16 x 32 Sport Pool; Hayward Series Sand Filter S244T
    15,000 Gallons, In Ground with New Vinyl Liner
    Pool approx. Five Years Old. Live in KY
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: Is adding around 100 ounces of bleach per day
    I am a SWG user, so no real help on amounts.
    I do know that if you are questioning your chlorine use, the only real answer is by doing an OCLT.
    OCLT Directions
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Jun 2014
    15,159
    If I did my Poolmath calculator correctly based on your pool size and CYA, that would appear to be 4.5 ppm each day which does seem a bit high. Somewhat explainable perhaps based on total exposure to sun, swimming load, CYA of 40, etc. You could always sneak that CYA up to 50 to try and save some FC per day. You could also post a full set of test results and/or do an OCLT just to be safe. Hope this helps.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    100oz of fresh 8.25% into 15k gallons is 4.4ppm. That is slightly on the high side of "normal" but not way out of line. Especially with a lot of use. Raising CYA a little more might help a bit but, not a lot.
    Jun 2014
    15,159
    Based my estimate on using 8.25% bleach.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,014
    Quote Originally Posted by Darren35 View Post
    In Effects of Adding Chemicals at the bottom of poolmath, it says 100 oz of 8.25% bleach in 15,000 gallons raises FC by 4.4
    In full sun with only 40 CYA and a lot of use, not unreasonable.
    The way to know for sure is to run an overnight loss test. If nothing's growing in the pool, you won't lose hardly any.
    If you don't have anything eating it up overnight, try raising CYA to 50. If you do - meaning you failed the OCLT - then you need to Pool School - SLAM - Shock Level And Maintain
    Jul 2014
    Evansville, IN
    72
    Thanks everyone. I have done oclt several times and I only lose approx ,5. I am raising cya.
    Jun 2014
    15,159
