Thread: Underwater cloudiness
    May 2012
    Henderson, TN
    234
    pH-7.5
    FC-6.5
    CC-0
    TA-90
    CH-70
    CYA-50
    The CYA is low but I have added stabilizer a day or so ago, so it is just not showing up yet. The TA is a tad high and the FC is a little high as it is coming down from the SLAM I did after opening. The pool looks as clean as ever, water is extremely clear, and you can see the bottom no problems. But when you go under, it's fairly cloudy. Any suggestions?
    35000 gallons
    Hayward Sand Filter
    Jandy AquaSeries Ei Pure Salt System
    IG
    Pentair Superflow 1hp
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Underwater cloudiness
    Raise chlorine up to 10ppm, turn off the SWG and Perform the Overnight FC Loss Test (OCLT) to see if there is any organic matter or algae in the pool consuming chlorine.
    May 2012
    Henderson, TN
    234
    It just passed the OCLT a couple days ago with no problems. Do I need to do it again?
    35000 gallons
    Hayward Sand Filter
    IG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    It might just be a matter of waiting for the sand filter to get the superfine stuff strained out. You could always try Pool School - Add DE to a Sand Filter
    Pool Owner Patience
    May 2012
    Henderson, TN
    234
    Yeah Ive got some DE but have not added it this year yet. It may just be patience. I'll keep and eye on it and update in a few
