Results 1 to 9 of 9
Thread: DIY IG POOL - part 7 - electrical
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hey there. I guess it’s time to talk about the electrical side of this pool.
    Once again, YOU MUST FOLLOW NATIONAL AND LOCAL CODES!!!!!
    The part I’ll concentrate on is bonding the pool. If you followed my advice you got steel walls for the pool. As we all know, metal (and water) are excellent conductors for electricity. As such, we need to prevent someone from being electrocuted while using the pool. The way to ‘bond’ a pool is by having a heavy duty copper wire run to a grounding post from all the metal within a certain distance from the pool, this includes, but is not limited to – the panels themselves, any ladders or handrails, the lights and the metal reinforcement in the deck.
    The way it’s done here is to surround the entire pool with continuous 16 gauge copper wire (some localities may require it to be coated) attached to the pool walls in 5 – 10 places, run through the outer bonding lug on the lights with ‘loops’ where any ladder/ handrail anchors will be and a couple of loops to bond the deck reinforcement steel.
    The easiest way to insure that this is done properly is to hire an electrician (who is familiar with local pool regulations) to do this, but it’s pretty darn simple to do – (anyone who wants the info can simply ask). However, you’ll probably have an electrician out to provide power to the equipment pad, so work with him (sometimes we’ll just have the electrician leave us the materials and install them ourselves, when he comes out to actually run the power to the pad, he’ll ‘sign off’ on what we’ve done so the inspector is happy).
    In Ct, the light niche MUST be bonded to the pool from the outside and back to the power source from the inside (it doesn’t matter that they share THE SAME LUG on the niche : hammer : ) and the inside has to have epoxy on it. Also the bonding wire on the inside MUST be coated!
    Some electricians will try to downsize the conduit (1” is good) and add too many bends or elbows – this makes ‘pulling’ the light cord through the conduit a real PITA!!! Unless you know how to properly wire junction boxes and add a breaker, it’s best to let the pros do this! Electricity can be very dangerous!!! (DUH !  )
    As long as you are going to be running some conduit – try to think ahead as to whether you are going to want lights around the deck, outlets near the deck and always have them run a 110 v waterproof outlet at the pad – it’s cheaper now than it will be in the future once the hole is closed up. Another thing to think about is, if you go with a shallow pool, installing a couple extra anchor cups, mid pool, so you can install a volleyball net – they will need to be bonded with the other cups.
    Again, I’ve probably neglected some stuff in this post (hint – it sure would be nice to hear from folks on the latest installments – I’ve done this stuff hundreds of times, I’d like to be sure I’m being clear as to what I’m trying to say)
    I think part 8 will cover shaping the floor – so be sure to stay tuned
    Luv& Luk
    -Ted
    Re: DIY IG POOL - part 8 - electrical
    Ted,
    In your second paragraph, I think you meant # 8 AWG around the pool.
    Chris
    Mar 2007
    4,160
    Thanks Chris, you're probably right Then again, maybe some localities allow the thinner wire (but I strongly doubt it) :P I'll leave it as I typed it, but I'm sure you're right Again, as I put in caps up top - FOLLOW THE LOCAL CODES!!
    Thanx for catching my error
    Luv& Luk
    -Ted
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I gotta go with Chris on this one, Waste. #16 copper is insufficient as a bonding conductor in almost any arena. Consider that even the wimpiest 15Amp home electric circuits use #14 conductors and most use #12, I wouldn't even attempt to bond with #16.
    I'd never try to go smaller than a #10 bonding wire, and would always rather have #8 or #6.
    Apr 2008
    Central Texas
    326
    Quote Originally Posted by waste
    16 gauge is the thinner wire. 8 gauge is nice fat stuff. 8)
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Also, Don't forget to bond or run the wire that connects all metal componets around the pool to the
    spa/pool motor and heater if applicable. This ensures everything to be at the same potetial.
    Chris
    NEC codes require #8 bare copper for bonding wire. Nearly every area bases their rules on the NEC codes, though often enough there are local changes. Thicker wire has a lower number, so using #6 might be alright, but I can't imagine 16 gauge ever being acceptable.
    Bonding rules can get quite complex and most inspectors will hold you to the details. There can be a big advantage to using an electrician who is familiar with the rules for pool wiring. They will know what all the local quirks in the code are. If you don't know what the rules are you risk delays from failed inspections. The actual work isn't all that difficult, the trick is knowing what you should be doing. If you can get either an electrician or an inspector to explain it to you in detail then it is usually simple enough.
    Some areas require that the work be done by a licensed electrician. Even then you can often find an electrician who will let you be their assistant and you do most of the labor while they make sure code is met and sign off on the job.
    Casey's Avatar
    SW PA
    10,457
    Re: DIY IG POOL - part 7 - electrical
    Bumping for ma23peas...
    Feb 2012
    Maryland
    400
    So Casey, did you ever get this pool complete? I know its been a while, im going to tackle my own DIY this summer.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
