Thread: new pool
    Jun 2015
    wichita ks
    2
    new pool
    hello im needing some help in understanding why with using our salt water / chlorine filteration system for over 12 hrs the chlorine isnt registering on the hth 6 way stip at all and ph is stillat 8
    Krbutler2000
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: new pool
    There is a possibility that your chlorine is so high it bleached out the test strips. That's just one of the reasons we dislike test strips so much around here. Pool School - Test Kits Compared
    The other possibility is that you have something growing in the pool that is using up all your chlorine as fast as the SWG makes it. If the pool was just filled and looks clear, that's unlikely.
    The pH will continue to rise from the Hydrogen gas released by the cell when it combines NaCL + H2O into NaOCl (bleach) and H2
    Have you checked out Pool School yet?
    Pool School - PoolMath
    Pool School - Water Balance for SWGs
    Jun 2015
    wichita ks
    2
    Re: new pool
    just to let everyone know im new to this. sry if you have seen multiple posts. thank you for your reply. last yr we had the liquid tester and strips so looks like i will be going to get more of the liquid. also pool looks really clear. its just ph levels are high and chlorine is 0
    Krbutler2000
