Thread: Silly Question
    Jun 2014
    Shrewsbury, PA
    69
    Silly Question
    This probably sounds ridiculous but I'm going to ask anyway...
    Do I HAVE to vacuum?
    The nearest leafed trees from my pool are about 600 feet away. I don't think there has ever been a leaf or a twig in the pool. Occasionally tiny clusters of dirt accumulate, but I have to look very hard for them. I've been vacuuming once a week anyway, just because I feel like a should. But do I have to vacuum if the bottom isn't visibly dirty?
    I'm sorry if this is a stupid question.
    18'x32' Oval Radiant - 15,000 gallons - Semi Inground (built into hill) - vinyl liner.
    Doughboy Powerline XP1 2Hp Dual Speed Pump
    Doughboy Silica II Sand Filter
    Installed 6/20/2014
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Silly Question
    No, you don't have to vacuum if you don't see anything that needs vacuuming. However, you should regularly brush the pool bottom and sides with either a pool brush or have a pool cleaner that does it for you most of the time.
    Isolated Spa - 345 Gallons
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Silly Question
    Not really. But, you do want to brush it occasionally to ensure that algae doesn't get a head start on you.
    chiefwej
    Jun 2014
    Shrewsbury, PA
    69
    Re: Silly Question
    Thanks! I will get to brushin'!!!
    Installed 6/20/2014
