Thread: Sand filter pressure?
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    154
    I have a sand filter; this is only the 2nd yr of use. After backwashing for almost 4 min and rinsing for over 2, I was able to get it down to 13 or 14...but never to the original starting point of 9 or 10. Pressure is stable and has been for several days. Both baskets are clean, water is flowing in and out, no excess noise from the pump, and gauge is not cracked or foggy. The water is clear, no algae. My questions: does it ever go back to the "brand new" reading, around 9 or 10? Do I still use the brand new reading to judge when I need to backwash or the new number? Thanks!
    Sent using Tapatalk
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    30,431
    Re: Sand filter pressure?
    Use the new number.
    When you get a chance you should open the filter and visually inspect for debris and that the sand bed is filtering correctly.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Yep, next time you are looking for something to do give this a whirl.
    Deep Cleaning a Sand Filter
    Jul 2014
    Hickory, NC
    154
    Thank you both, I had actually bookmarked that link about 2 weeks ago...I thought it was interesting how all that junk accumulates (and gross lol).
    I did think it was interesting that my pressure goes down about 1-2 psi when I have the main drain closed. I don't know if this is significant but I thought it would be the opposite. (My main drain was open when I wrote the original post...everything is still around 13-14 psi).
    Sent using Tapatalk
    ~ TF-100 test kit
