Thread: Just installed my new Circupool RJ60 how do i set the run time??
    Aug 2014
    Jacksonville/Fl
    26
    I Just installed my new Circupool RJ60 how do I set the run time
    I have read through the manual and looked online with no luck?? Thanks
    18 x 32 Hydrazzo
    Pentair Wisperflo WFE-3
    Hayward Pro Series 24 sand filter feeding a Hayward C1200 Star Clear Plus Filter
    Circupool RJ60 Salt system
    38,290
    Re: Just installed my new Circupool RJ60 how do i set the run time??
    The SWG does not have a way to control the run time ... the power should be supplied to the SWG from the same timer as used for the pump.
    You just set the % output (which is the % of generating time vs not generating time) and the time controls the on/off.
    Here is the manual. Read pages 7-9:
    http://discountsaltpool.com/CircuPoo...tor-Manual.pdf
